+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Junior Member level 2
    Points: 1,234, Level: 7
    Join Date
    Oct 2006
    Posts
    23
    Points
    1,234
    Level
    7
    pic18 sht11 code
    please everybody, how to build data logger for humidity and temperature using atmel ISP, thank's for your cooperation.
    rgds,
    gie
    •   AltAdvertisement
  2. #2
    Advanced Member level 3
    Points: 10,724, Level: 24
    budhy's Avatar
    Join Date
    Oct 2006
    Indonesia
    Posts
    828
    Points
    10,724
    Level
    24
    humidity sensor shtxx
    Use Sensiron SHT11 digital humidity sensor
    with the following features :
    * 2 sensors for relative humidity & temperature
    * Precise dewpoint calculation possible
    * Measurement range: 0-100% RH
    * Absolute RH accuracy: +/- 3% RH
    * Temp. accuracy: +/- 0.4C @ 25 C
    * Calibrated & digital output (2-wire interface)
    * Fast response time < 4 sec.
    * Low power consumption (typ. 30 W)
    * Low cost
    * Designed for high-volume applications
    * Leading CMOSens Technology for superior long-term stability
    * Very easy-to-use due to calibration & digital 2-wire interface
    The C source code for driving SHT11 :
    Sample Code humidity sensor SHTxx orginial c file (ZIP Version)
  3. #3
    Join Date
    Oct 2006
    Posts
    23
    Points
    1,234
    Level
    7
    shtx pic c18
    Thank's budhy for your reference, but the device may be need any circuit/driver?so coudl you to help me to find circuit/driver for this application(i hope you can give completely circuit/driver).
    once again i'm many thank's to you for help me and coorporate.
    rgds,
    gie
    •   AltAdvertisement
  4. #4
    Points: 8,490, Level: 22
    Join Date
    Nov 2006
    Posts
    982
    Points
    8,490
    Level
    22
    humidity driver sht1x dewpoint calculation
    Use the bridge configuration for humidity along with opamp and lm35 temp sensor.
  5. #5
    budhy's Avatar
    Join Date
    Oct 2006
    Indonesia
    Posts
    828
    Points
    10,724
    Level
    24
    hs1101 appliction c51 code
    Please take a look at The SHT1x / SHT7x Humidity & Temperature Sensor data sheet for more information.
    The circuit to connect SHTx to a microcontroller just like this :
  6. #6
    Points: 1,078, Level: 7
    Join Date
    Jan 2007
    Posts
    Points
    1,078
    Level
    7
    keil hs1101 driver
    Hi
    humidity-sensors are SHT11 and HS1101
    Ado
    •   AltAdvertisement
  7. #7
    Join Date
    Nov 2006
    Posts
    982
    Points
    8,490
    Level
    22
    connecting hih3610 to avr
    check 8052.com for code
  8. #8
    Member level 5
    Points: 1,933, Level: 10
    Join Date
    Aug 2006
    Posts
    84
    Points
    1,933
    Level
    10
    interface tmp36 to pic18f
    If yours controller has analog inputs, you can use much cheaper HIH3610 for humidity (connects directly to ADC channel) :
    http://www.aagelectronica.com/pdf%20docs/hih3610.pdf
    http://www.phanderson.com/hih3610.html
    http://www.phanderson.com/picaxe/hih3610.html
    and DS18B20 (digital), or TMP36 (analog) for temperature measurements
