What tools can open .Z files in Windows?
dd2001
Full Member level 4
Hi, all
I don't know what tools can open .Z file in Windows? I tried WinRAR, it does't work.
Thanks.
how to open .z
Hi
As far as I know it is UNIX compressed file, use uncompress <filename>.Z
In windows you can open with winace and get a tar, but I do not any file to try. A software called picozip can open .Z files so try that if you use windows (https://www.picozip.com). Maybe you cannot read it anyway but give it a try...
open z files
I have tried to use winzip in some .Z file and it works well.
But if in your situaton it doesn't you can try Wingzip from GNU, it's the similar application of the gzip of UNIX.
Hope helps,
NeuralC
open .z file
For UNIX or linux, use : uncompress
For windows, dwld and use : picozip
For DOS, use attached software : compress -d xxx.z
OkGuy?
Re: How to open .Z file?
dd2001 said:
Hi, all
Thanks.
I've had opened my every .Z file in Windows using WinZip (I have version 8 )
regards,
Eirp
For UNIX or linux, u can use the system tool: uncompress
For windows, u can usethe partt tool: winrar
