+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Junior Member level 2
    Points: 1,408, Level: 8
    Join Date
    Apr 2006
    Posts
    23
    Points
    1,408
    Level
    8
    resolution of 12bit SAR ADC
    I am currently working on a low speed SAR ADC(around 10KHz sample rate)
    is it possible to get a 12bit resolution with 6bit(from resistors) + 6bit (from capacitors)?
    i know it's possible to get 10bit from poly resistors, but not so sure about capacitors.
    •   AltAdvertisment
  2. #2
    Advanced Member level 1
    Points: 4,135, Level: 15
    Join Date
    Apr 2004
    shanghai,china
    Posts
    453
    Points
    4,135
    Level
    15
    Re: resolution of 12bit SAR ADC
    why not? The capacitor has better match quality.
    •   AltAdvertisment
  3. #3
    Points: 3,416, Level: 13
    Join Date
    Jul 2005
    Posts
    410
    Points
    3,416
    Level
    13
    capacitor is better
    •   AltAdvertisment
  4. #4
    Member level 4
    Points: 2,599, Level: 11
    Join Date
    May 2005
    Posts
    75
    Points
    2,599
    Level
    11
    Be carefull...
    6 bit MSB should have 12 bit accuracy not 6 bits. Neither resistor (~8 bits) nor capacitor (~ 10 bits) will give you 12 bit accuracy if you do not employ circuit techniques (like calibration, trimming ).
