how to install uncompress command?
quan228228
Full Member level 4
uncompress rpm
I found my linux hasn't uncompress command. How can install this command? My linux is RedHat 8.0.
Thanks !
rpm uncompress
go to rpm.pbone.com and find unzip and unrar and untar packages
this is the unrar >>>> unrar
    quan228228
uncompress linux download
gzip can uncompress the .Z file. If some software need uncompress command, just create a link from gunzip:
ln -s gunzip uncompress
    quan228228
linux uncompress command
You can download the uncompress rpm for RH 8 and install it.
redhat uncompress
just download a RPM package of zip, rar, unrar, gzip, bzip and bzip2, etc. there are a lot of software to do it
linux uncompress download
I remembered that synopsys used umcompress in its intallation script before. If your linux system does not have this command, you can use zcat instead.
Put an alias in your .cshrc file, such as:
alias uncompress zcat
install uncompress
its an old utility. Now 'uncompress' command is an interface to 'gzip' utility. Either install 'gzip' or put a link from 'gunzip' in your $PATH.
uncompress redhat
For Fedora, install the ncompress rpm package and you get both compress and uncompress.
u can use
unzip for zip file
gunzip gunziped files
