G
Dear Sirs
I need to test an inductive load with a low level high frequency current signal. In normal operation the inductive load is feed by a DC voltage source. Test goal is to inject the AC signal with the DC Power simultaneously. Basically what I need is to add two analog signals. One is the low level high frequency test signal, and the other is the high lever DC power signal.
All information will be appreciated.
Thanks in advance by your support
Best Regards
Pendragon
Best Regards
Pendragon
