+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Junior Member level 1
    Points: 1,282, Level: 8
    Join Date
    Apr 2006
    Posts
    15
    Points
    1,282
    Level
    8
    Four-bit long, four-bit wide bidirectional dynamic shift register
    want information abt A four-bit long four-bit wide bidirectional dynamic shift register
    •   AltAdvertisement
  2. #2
    Advanced Member level 5
    Points: 32,456, Level: 44
    Join Date
    Apr 2002
    USA
    Posts
    3,942
    Points
    32,456
    Level
    44
    help needed urgent
    What kind of information do you need?
  3. #3
    Join Date
    Apr 2006
    Posts
    15
    Points
    1,282
    Level
    8
    Re: help needed urgent
    i want to know what 4 bit long 4 bit wide means first of all bcos i didnt understand what it is..
    and what does dynamic shift register means.. i mean the significance of word dynamic...
    i was given this project n i didnt understand anything abt this.. so please help me
    •   AltAdvertisement
  4. #4
    Join Date
    Apr 2002
    USA
    Posts
    3,942
    Points
    32,456
    Level
    44
    help needed urgent
    Here's a general description of a shift register:
    http://en.wikipedia.org/wiki/Shift_register
    "four-bit long four-bit wide": The shift register stores four data words. Each word contains four bits.
    "dynamic": This usually means that each bit is stored in a capacitor (usually implemented as a MOS transistor) instead of in a flip-flop.
    "bidirectional": You can shift the data from left-to-right, or from right-to-left.
  5. #5
    Join Date
    Apr 2006
    Posts
    15
    Points
    1,282
    Level
    8
    iam sorry, i dont want to bother u but here is the title of my project and i think it has a lot of twists..... please look at it and help me..
    A four-bit long, four-bit wide bidirectional dynamic shift register circuit, without parallel inputs and without parallel outputs, should be realised using CMOS inverters and transmission gates to build the dynamic D-FF's in the pseudo two phase clocking scheme. A transmission gate 4*1 mux should be used to connect data to the flip flop input. The circuit should support four modes of operation: refresh (00), shift right (01), shift left (10), and clear(11).
    please help me understand this..
    and can anyone please tell me the applications of bidirectional dynamic shift register....
    •   AltAdvertisement
  6. #6
    Join Date
    Apr 2002
    USA
    Posts
    3,942
    Points
    32,456
    Level
    44
    help needed urgent
    Without parallel inputs and without parallel outputs?? What I/O does it have?
    That sounds like a breadboard or ASIC project. You can't implement CMOS transmission gates in an FPGA or CPLD, which is the subject of this discussion forum.
  7. #7
    Join Date
    Apr 2006
    Posts
    15
    Points
    1,282
    Level
    8
    help needed urgent
    it has to b implemented in cmos n right now we r tryng a layout for it.. the circuit has about 130 transmission gates....
