+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Full Member level 3
    Points: 1,958, Level: 10
    Join Date
    Aug 2006
    Posts
    155
    Points
    1,958
    Level
    10
    what is difference between.....
    divergence and curl of a vector
    stoke's theorem and divergence theorem
    motional and transformer induction
    •   AltAdvertisement
  2. #2
    Full Member level 1
    Points: 2,867, Level: 12
    Join Date
    Jul 2006
    Posts
    100
    Points
    2,867
    Level
    12
    Re: what is difference between.....
    Hello !
    1. Divergence is an opertator of transformaing a vecotr to scalr (del(A))
    and Curl is vector multiplication of the del op. with any given vector: del X A
    (the del op. is called also sa nabla and its defined is the parlty derivative of the x, y and z componnent).
    the reusltent is a vector which prependicualr to the two multiplied vectors (in our case the del op. vector and the A vector)
    2. The Stoke's Theoremrelates a clused line integration to a surfcace area bounding it.
    and the Divergence Theorem relates the closed surface of a body to its volume by the div. op.
    About the 3rd pair - I don't know !
    Hoped I helped !
    •   AltAdvertisement
  3. #3
    Full Member level 2
    Points: 2,742, Level: 12
    Join Date
    Jul 2005
    Posts
    132
    Points
    2,742
    Level
    12
    3. Motional and transformer EMF:
    Motional EMF is the emf induced due to the relative motion between magnetic flux lines (whether of fixed field or not) and a conductor, [i.e. like moving a coil in a magnetic field, like that which is induced in a generator]; while the transformer emf is the induced emf by electromagnetic couplying between two objects, which don't move relative to each other, due to time-varying current, volt or magnetic field in one of the objects.[i.e. Like that in the transformer]
    :D
