btbass
Advanced Member level 5
rc5 pic example
Good to hear the code works ok for you.
As for the noise, first check that there isnt something else transmitting. I once had a problem and it turned out that my laptop was intermitantly sending out ir signals.
also, the IS1U60 has quite a good optical filter that blocks out non ir sources.
I will try to optimise the code so that when it is calibrating the pulse length, it checks that it is close to 1.8mS long and rejects it if it isnt.
Also, after using the results, set rc5valid to false.
To get better results, a resonator or xtal is better than a rc oscillator for clock source, but with a 12F629 I dont suppose you have that choice!
