C++ or Java for getting real time data serially
omrox
Junior Member level 1
which of the following programin language can be used either c++ or java, for getting real time data from real world serially ( via serial port to the PC ). kindly suggest me the direction to proceed.
Re: C++ or Java
any lanaguage can be used
java is free
c++ is free
both are fine at the level they function at
c++ is a lower level language then java as java reuses c++ componenets
but this makes java a little faster and nicer interfaces are easier to make
just a little extra code is needed for exception handling
if your new to programming
use c and c++ then java when you learn c++
a tip is to have lots of example sources
here is some cd volumes for c++
they are cheep and downloadable
    omrox
Re: C++ or Java
Actualy I prefer C/C++, I feel they are more relaibale in embeded and realtime systems.
Regards,
Shohdy
C++ or Java
D'ont forget Java have always a JRE at the midle, so performance is lower thant C++ (compiled directly for the OS), so in some scenarios of realtime JRE brings problems..
HH
NeuralC
Re: C++ or Java
Assalamo Allykum !
I Think the C/C++ is best for your reequirement.
I prefer to use C/C++ for the serial communication.
On the otherhand Visual Basic 6.0 is another good option for you that you can use for serial communication.
Take Care :D
Zeeshan Shareef :!:
Re: C++ or Java
With C or C++ you have direct access to serial ports, its easy to control and R/W from serial ports.
I do not suggest JAVA for these things.
Re: C++ or Java
go for C or C++ , they are made for doing things like this , whereas java is more of an network language, so u may also use java, but C++ would be simpler and faster.(in writing program).
and you may easily find some code in C/C++ on this....
check out www.beyondlogic.com
bye
Re: C++ or Java
when u interact with hardware, c / c++ is the best
Re: C++ or Java
i think C++ has more systems commands for such purposes, also many drivers are written in C++ so i would suggest u to use C++
Re: C++ or Java
hi guys,
these are from my point of view and real life experience:-
for embeded programming --- C is the best.
for application development for general purpose computer where memory is not a concern and slight speed reduction is also not a concern : JAVA is really the best. currently it is the language of choice for most application programmer(for general purpose computer and web based applications).
also you can put c code/programs in java code where necessary. and also java really got a futurestic look.
c++ is the between of these two languages. and i should tell ther is very large difference between C and C++. so dont mix the two. Java looks much more than C than C++.
arnab
Re: C++ or Java
do i have to know C to begin studying C++??
Re: C++ or Java
No you don't have to study C.
I think it is better for you to study C++ in order to really understand object oriented programming.
This is a powerful programming paradigm and it should allow you later on to learn more easily Java and other similar languages
Re: C++ or Java
I think you should learn C before C++.
C is a base of C++ programming.
C is more easy and you'll spend less time to understand C-programming.
After that you can learn C++ - when you know basics it's very easy to learn some new useful features.
C++ or Java
well, is depend on the need of the program ... for me i will go for c/c++ , more straight forward to be implement
Re: C++ or Java
for me C++ is better because it is user friendly than java.....
Re: C++ or Java
start programming using any language. You would have been done by now..The "C++ or Java" argument will never end so don't wait for it.
Oh...and C is nothing like C++. Keep that in mind
C++ or Java
Yep...i agree with eusto!dont get stuck making a choice..once u start with any language..picking the other one will be a piece of cake..lietrally!!!
All the best!
Re: C++ or Java
the best programming language is CCCCCCCCCCCCCCCC
