Unable to run Matlab 7
ciitv
Junior Member level 2
i'm unable to use matlab 7 on Windows XP SP2 now. when i run the matlab program the flash screen appears and disappears but nothing happens(no
workspace). it was working when i last used it a couple of months ago.even the m file editor and un-install programs do not run now.
i tried re-installing by running the setup file from the cd. but again the flash screen appears and then disappears and no further installation options appear. i deleted the entire matlab folder and i still can't re-install.
the only major change i've made to my comp since matlab last worked is the 1) installed SP2 2)stopped some of the services running on system to make it
run faster. i'd appreciate ur suggestions. thanks in advance.
hi
consult microsoft an d math works sites..send them a technical support question ..
regards
I had a similar problem after upgrading to SP2 (couldn't get to the workspace, unistaller didn't work, etc.) I had to go in and delete the entire matlab folder myself, then run the CD installer, after which matlab worked as it should.
it could be that there is still registry entries accepts left over
uninstall it and delete the folders
use a reg cleaner to get rid of all the left over keys
shut down and restart
then reinstall
try 16bit mode for the video system
hello, I only recently installed Matlab, what u need to do is to first check to see that ur system has the capability , i mean in terms of memory 'n all to run d software. u might want to uninstall the previous version first.
