+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Advanced Member level 5
    Points: 15,234, Level: 29
    khouly's Avatar
    Join Date
    Oct 2003
    EGYPT
    Posts
    2,368
    Points
    15,234
    Level
    29
    How to use a 0.13 um MOSFET for HSpice in MWO?
    i have a mosfet 0.13 um for hspice , and i want to use it in MWO
    is there any examples or hints to do so
    thanks in advance
    khouly
    •   AltAdvertisment
  2. #2
    Advanced Member level 3
    Points: 10,596, Level: 24
    Join Date
    Aug 2005
    INDIA
    Posts
    810
    Points
    10,596
    Level
    24
    Re: MWO mos model
    Hello khouly,
    Very Simple...
    To import HSpice Netlist just Right click on Circuit schematics -> select Import Netlist -> Change the Files Type to HSpice Netlist Files (*.sp, *.inc) then chose the file...
    Create New Schematic call this as subcircuit to reuse...
    ---manju---
    1 members found this post helpful.
    •   AltAdvertisment
  3. #3
    Full Member level 6
    Points: 5,453, Level: 17
    madengr's Avatar
    Join Date
    Apr 2005
    Kansas City
    Posts
    394
    Points
    5,453
    Level
    17
    Re: MWO mos model
    Here is a MWO project file. I'm not sure if it will work in version 6.5, but I saved it as that anyway. I did it in 7.01 and also have the HSPICE option.
    As suggested you can import the spice text directly but you may have to wrap it in a subckt and make sure the ports numbers match up. You must also paramaterize L and W.
    I used the model block instead but then you must enter the model parameters by hand. I did NOT put in your parameters (I'm too lazy) so you must do that.
    •   AltAdvertisment
  4. #4
    Full Member level 6
    madengr's Avatar
    Join Date
    Apr 2005
    Kansas City
    Posts
    394
    Points
    5,453
    Level
    17
    Re: MWO mos model
    I did try as Manju said and it does import it. Only saw the first model so you may have to break it into two files. You'll need to figure out the port numbers since it comes in as a generic 4 port. I do think to define L & W you may have to paramaterize it with a subckt.
