chang830
Full Member level 5
I have a question on the vias number and peak current.
I am designing an output inverter to drive cap load. To drive this load, the peak current is high up to ~100mA when trasistion. I found the max static current for the vias of the drain and source region is ~1mA per via. Obviously, I can not put 100 vias to tolerate this 100mA current.Then this instant current will affect the long term reliability of the device?
I know, for the VDD/GND metal width, the width is dertermined by the avarage cuurent in WCS,instead of the peak current. Is it also applicable to the VIAS?
In this case, should I put more fringers to loose the current burden?
Thanks
Thanks
