IAR EMBEDDED Workbench for ARM
memarian
Full Member level 5
Dear Friends,
I want to use ARM9E (STR91x)DSP Instructions on IAR EMBEDDED Workbench for ARM(and Also Keil).
Does anyone know how can i force the IAR C Compiler (or Keil For ARM)to use ARM9E DSP Instructions
(Specially for Multiply & Multiply-Accumulate & Memory Loading Instructions)?
Thanks.
Hi
While setting the project you can set the compiler to work with a dedicated microcontroller or you can choose a technology by selecting the controller femiliy.
all the best
Bobi
Dear,
I set my microcontroller in project setting (Also try it's family) but when i going to
simulate program in Disassembley window when i see the assembley instructions
it doesn't use the DSP Instructions.For Example for muliply-accumulate instruction
it uses MLA (typical ARM Instruction) not SMLA(ARM DSP Instruction).
Thanks.
Hi
If the compiler dose not support using the right assembly code you have to use a mix of assembly and C language in order to force the compiler using the right assembly code.
All the best
