Power supply design (timer)
JS-john
Newbie level 3
Hi. How I can design power supply which can timer or delay for on/off . Pls suggestion me by circuit , website or ...
thank ..JS-John
Dear,
if your power supply has low voltage,you can use regulators with shutdown pin
(like as LM2931-adj) and connect timer to shutdown pin.for high voltage you can use
a Relay and connect timer out put to relay command.
Good Luck.
