+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Junior Member level 3
    Points: 1,380, Level: 8
    ezbentley's Avatar
    Join Date
    Apr 2006
    Posts
    31
    Points
    1,380
    Level
    8
    Input bias of transconductor
    Since a gm cell works in an open loop fashion, how is the input bias determined? Should the gm cell include an internal biasing circuit to set the input point voltage?
    However, from some gm-c filter diagrams, it doesn't seem like there is internal bias, because some applications ground one of the input of the gm cell.
    •   AltAdvertisment
  2. #2
    Full Member level 6
    Points: 3,329, Level: 13
    Join Date
    May 2005
    Egypt
    Posts
    350
    Points
    3,329
    Level
    13
    Re: Input bias of transconductor
    Perhaps the grounded input is an ac ground..?
    I think that fully-differential gm-C would use a common mode feedback loop to determine dc bias. Probably, the input and output of the stage have the same dc point and the stages are dc-coupled after that...( not sure about that )
    1 members found this post helpful.
    •   AltAdvertisment
  3. #3
    Member level 3
    Points: 1,916, Level: 10
    Join Date
    Oct 2005
    Posts
    54
    Points
    1,916
    Level
    10
    The input bias is determined by a number of things, including common mode levels and the maximum output current that you need.
