How to determine the ring oscillator tuning range?
khorlipmin
Member level 3
How to determind the ring oscillator tunign range? What is the first measurement that I should be doing? and where shall I go from there? thanks
cadence parametric analysis vco tuning range
try to refer to the cadence or ADS manual
good luck!
Re: VCO tuning range.
Cadence spectrumRF
parametric analysis set a variable
I think you need to sweep the control voltage of the VCO between the min and max possible values, and measure the frequency output. The tunning range is the diffrence between the min and the max frequencies you can get out of the VCO.
Regards,
Shohdy
hi,
i m sorry that i dont understand the procedure.if i dc sweep control voltage how can i measure frequency?is it possible in hpsice?if than what will be the netlist?
please help me,please
