lcd interfacing to pic 16f877a problem
farfor
Newbie level 1
hd44780a datasheet
when displaying strings like "welcome" on 2x16 lcd
the display doesn't appear except after pressing the reset key several times
lcd driver 16f877a
Looks like timing problem.
Are you using delays in your code to initialize your LCD?
If yes, how long have you delayed at each stage?
Cheers,
lcd interfacing with pic
Post your initilising code - so it can be reviewed by all to help you.
Have you got the data sheet for the Hitachi HD44780A?
I think the data sheet can be misleading.
Polymath
hd44780a pic lcd
have u checked the voltage for your lcd? do you have a rheostat connecting to your lcd circuit? if you do try varying it. maybe its abt the intensity.
pic24 lcd power problem
Hi.
I had same problem. It was because because i didnt wait enough after each data transmision. Try to make larger delays.
I agree with the posts above. When I wrote a wait function it din't work too. But then I measured the timing of the wait function using an oszilloscope I saw that the timing was not correct. After we corrected this function the lcd works. To be independent of the compiler you should use assembler instead of c to realize the wait function.
greetings,
hqqh
Refer 8052.com
Though this is PIC you can get good details on LCD
hi
after power up, LCD need to take about 20 ms before first command is sent.
I made it several times and it is working good.
Hi,,Put a capacitor of 2200 Mf in your source an try again!...Fran!
here is the lcd driver i wrote in c for comvdd ebox design
you can reuse it if you like
or view it too see where you went wrong
this lcd driver works fine
dont forget to check you setup the clock and xtal right !!!
Re: hd44780a datasheet
Put appropriate delays..check the contrast pin too.connect it to ground using a pot and varry the pot..u'll get it
