+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Member level 1
    Points: 2,693, Level: 12
    Join Date
    Aug 2005
    Posts
    36
    Points
    2,693
    Level
    12
    PLL terms?
    hi
    Can you pls explain the meaning and physical significance of the following terms which we usually use with PLL.
    1. Natural frequency ( Wn)
    2. Loop bandwidth. (Wc)
    yours
    SavithRu
    •   AltAdvertisment
  2. #2
    Advanced Member level 1
    Points: 3,875, Level: 14
    Join Date
    Mar 2006
    Culiacán, Sinaloa, Mexico
    Posts
    479
    Points
    3,875
    Level
    14
    PLL terms?
    Every electronic device tends to oscilate to a specific frequency called Natural frequency. Even a mechanic device tends to oscillate to a frequency called natural frequency.
    The other term is very specific, is the bandwith of the device in the feedback loop.
    •   AltAdvertisment
  3. #3
    Member level 3
    Points: 1,732, Level: 9
    Join Date
    Jan 2006
    P.R. CHINA
    Posts
    55
    Points
    1,732
    Level
    9
    Re: PLL terms?
    the nature frequency exists in a closed loop system;but the wc exists in an open loop system.
    you can calculate wn in root locus by the closed loop root .
    and you also can get wc by phase margin. that is my thought.
    •   AltAdvertisment
  4. #4
    Member level 1
    Join Date
    Aug 2005
    Posts
    36
    Points
    2,693
    Level
    12
    Re: PLL terms?
    Thanks a lot for giveing me the insight on these rems..
    I need to know few more terms...
    kindly tell me what exactly are these wrt pll.
    kindly tell me what are these Δf and α in the following eqn of ts.
    4.3. Settling time
    Settling time is another important performance metric that is directly related to the
    loop transfer function. Settling time determines how fast the frequency synthesizer
    can change the frequency of its output signal.
    An analytical solution for the settling time can be obtained from the step response
    of the closed-loop transfer function, see Eq. (10). Settling time is a function
    of the natural frequency (ωn = √KDKo) and the damping factor (ζ = ωn/(2ωz)).
    It can be shown that
    ts=
    ( 1/ ζωn) * ln { Δf/ (α fo sqrt(1 − ζ2) } ......................if ζ < 1 (under damped )
    ts=
    (1 / ζωn) * { ln (Δf / αfo ) } ................if ζ = 1 (critical)
    ts =
    (1 / (ζ −sqrt (ζ2 − 1)) ωn ) * ln { Δf(sqrt (ζ2 − 1 + ζ)) / (2αfo sqrt (ζ2 − 1)) } ......... if ζ > 1 (over)
    (17)
    where fo is the frequency from which the synthesizer starts the transition, Δf is the
    amount of frequency jump, and α is the settling accuracy. As the loop bandwidth
    ωc increases, the settling time gets shorter if the damping ratio is fixed. The effect
    of the damping ratio on settling time is shown in Fig. 11. It is a plot of Eq. (17)
    with ωc fixed but not ωn, which is more realistic in the sense of design procedure.
    In this condition, the settling time is fastest when the loop is critically damped, and
    further underdamping does not improve the settling time. Note that the analytic
    solution in Eq. (17) is only an approximated result for the second-order closed-loop
    Added after 10 minutes:
    pls tell me that what are these terms wrt pll .
    1. α = settling accuracy..
    2. Δf = amount of frequency jump.
    kindly answer.
    SavithRU
  5. #5
    Points: 11,124, Level: 25
    Achievements:
    7 years registered
    safwatonline's Avatar
    Join Date
    Nov 2005
    EGYPT
    Posts
    1,347
    Points
    11,124
    Level
    25
    PLL terms?
    settling time is the time need when introducing a frequency step (delta f) , we say the the loop is setteled "locked" when the frequency is less than a certain settling accuracy.
    i.e. when freq. synthesizer change its frequency by
    delta f=50MHz and if the setling accuracy is 10kHz >> we say the loop is locked when the frequency is less than ff+10k And
    the frequency is more than ff-10k.
    ; ff is the final freuency value = fo+ delta f >> fo=initial freq.
    delta f =freq. step
