Help me interface a HD44780 LCD Screen to PIC18F4550
Slayerza
Full Member level 5
South Africa
LCD Screen Help
I need some help interfacing a HD44780 compatable LCD screen to the PIC18F4550.
I am however having some problems, I recompiled the header as the datasheet? said. However even after increasing the dealy time significantly, the screen still does nothing. I am sure the screen is functional as is is brand new. The screen is a LMM86S027C2E from Nan-Ya (aka Mark products).
Please help.
Thanks in advance
Slayer
Re: LCD Screen Help
You are not saying much, at least nothing much to go on. However, you do say:
which makes me wonder how you have the contrast hooked up? Is your contrast pin hooked to the center of a 10k or 20k potentiometer which runs from Vdd to Vss? Even without code to drive it, the display should show you some dark rectangles by turning this pot. Can you get these?
If not, then before you blame your code, have a look at the hardware end.
If so, then are you in nibble, or byte mode? I would guess that by:
you were referring to a Microchip App Note?
Are you working in assembly, or C? If in C, which tools are you using?
Regards,
Robert
Re: LCD Screen Help
Im using the C18 compiler from microchip and the datahseet I am refering to is the C18 C compiler libraries. I have stepped through the code and noticed that in the controller datasheet the following happens,
In the datasheet there are two instuctions below each other in a frame. like
0 0 0 0 1 0
0 0 1 1 0 0
The microchip code then produces 0 0 1 1 1 0 and transfers this to the LCD. I dont know if this is causing the problem.
I have the contrast hooked up and the little squares are showing. Also I am using the nibble (4bit) mode
Thanks
Slayer
Re: LCD Screen Help
Hi Slayer,
It's late for me, and I'm falling asleep, but looking at the Microchip library guide, I came across this:
lcdtype
A bitmask that is created by performing a bitwise AND operation (‘&’)
with a value from each of the categories listed below. These values are
defined in the file xlcd.h.
I was looking for this:
0 0 0 0 1 0
0 0 1 1 0 0
It seems to me that there is a connection here; those values are anded.
I'm a little confused, though, by "In the datasheet there are two...," were you referring to the LCD data sheet?
Regards,
Robert
