Results 1 to 3 of 3
    Points: 2,577, Level: 11
    Jul 2001
    North Silicon Valley
    35
    2,577
    11
    The working theory behind the voltage control circuit in this copitts common base VCO
    Hi :)
    Can any one tell me the working theory behind the voltage control
    circuit in this copitts common base vco[attached jpg].
    The voltage control ckt is in the centre of the figure. So plz explain
    the following:
    *purpose of resistor[1000ohm] from between transistors. Center and left transistor
    *why we use a current source/mirror to pull the center transistor
    *the capacitor at the volt control port: between the center transistor
    and current mirror.
    Also, this schematic is in @DS, but if I were to simulate it in C@dence
    what ports would I need and were would I stick them?
    thnx
    Sparrow
    Advanced Member level 3
    Points: 13,776, Level: 28
    Feb 2002
    749
    13,776
    28
    vco theory
    The details in the jpg-file is not readable. Can you provide the ADS project files instead?
    Jul 2001
    35
    2,577
    11
    theory of vco
    Here it is.
    I did not .rar it, just change the extension from .rar to .zap
