Using XLCD library from C18 compiler
Slayerza
Full Member level 5
South Africa
I have read some documentation that the C18 compiler from microchip includes a library to drive an exteranal LCD screen (xlcd). However, I understand that some changes needs to be made in order for this to work correctly. My question is if anyone has used this library successfully.
Thanks in advance
Slayer
xlcd c18
yes it worked fine with the displays that I am using. However one (small) caveat - I didn't get them to work without the BUSY pin.
Best Regards,
c18 lcd library
Can you explain what you did to solve the problem?
xlcd library
Well - I simply used the busy pin on the 44780...
