chanduchi
Junior Member level 2
Hi
Iam facing displays flickering problem since last 20 days.
Iam using delay but I am not able to salve it
Here iam using 74LS373(4) latches.
Iam sending the data through PORT 2 and enable the latches using PORT 3
Iam using ADC804+89c51+74LS373(4 numbers) +7 seven segment displays (4 numbers)
Please check my code given below and give me a proper ‘C’ code for this problem.
Thank you
Regards
Nari
This code i used in my project
sbit c1=P3^0;
sbit c2=P3^1;
sbit c3=P3^2;
Sbit C4=P4^3;
s1,s2,s3,s4=data;/* Example:data=4.943v.*/
while(1)
P2=s1; /* data=4*/
c1=1; /* Latch enable*/
Delay(100);
c1=0; /* Latch disable*/
P2=s2; /* data=9*; '.'=constant */
c2=1;
Delay(100);
c2=0;
P2=s3; /* data=4*/
c3=1;
Delay(100);
c3=0;
P2=s3; /* data=3*/
c3=1;
Delay(100);
c3=0;
void Delay(unsigned int time)
unsigned int i,j;
for(i=0;i<time;i++)
for(j=0;j<1275;j++);
Thank you
Regards
Nari
sbit c1=P3^0;
sbit c2=P3^1;
sbit c3=P3^2;
Sbit C4=P4^3;
while(1)
P2=s1; /* data=4*/
Delay(100);
c2=1;
Delay(100);
c2=0;
P2=s3; /* data=4*/
c3=1;
Delay(100);
c3=0;
P2=s3; /* data=3*/
c3=1;
Delay(100);
c3=0;
unsigned int i,j;
for(i=0;i<time;i++)
