leonken
Full Member level 3
power disspation
I want to analysis the power dissipation of a switched power supply circuit using Hspice.
I have some problems:
1. For the input voltage source, the current flow through it is not a constant.
Shoud I use voltage* RMS current or voltage*average current or some other method to calculate the power dissipation of the input source?
2. For the switche, the voltage acorss it and the current flow through it are not a constant. Should I use RMS voltage* RMS voltage or average voltage*average current to calculat the poewer dissipation? or some other method?
3. The command .meas avg/ rms is suitable for calculating the power dissipation? or some other method in Hspice?
