patato
Junior Member level 2
I mean, when given certain spec such as slew rate,bandwidth, gain etc.,I start to implement my circuit, following steps on the textbooks.
But what if a two-stage or fold-cascode doesn't fit in? Textbooks only tell me that "if u are using A structure, you can blah blah blah". The real problem is how do i know if A is the best(or worsest) structure for my target?is it simply try & error to get the right solution? or there's a table or something can be used for reference?
it's confusing me quite some time.
I really need some advice about it.:|
