HOW to transfer VCD to WGL format
kermit
wgl format
In the design, there are some logic to test PHY, so I use simulation to generate VCD file to generate stimulus and get results for tester. But test house want to get WGL format.
I have Encounter Test tool to generate FULLSCAN test pattern file (WGL format), how to translate VCD file to WGL file ???
vcd to wgl
check in simvision user manual.
wgl vcd
simvision use manual dont include any information about translate VCD to WGL format.
OR who can share IEEE std 1450 ?
wgl file format
Please check the following link:
http://www.sourceiii.com/products/vtran/datasheet.html
vtran -- Canned readers are currently available for the following file formats
1) Verilog VCD (and EVCD) files <-------------------- VCD/EVCD
2) Toshiba TSTL2 files
3) Mentor LOG files and FORCE files
4) WGL and TSSI TDS ascii files <-------------------- WGL
5) Valid Tabular I/O files
6) Fujitsu FTDL files
7) Synopses VSS WIF files
8) IMS Test MEM format files
9) TDL_91 format files
10) Quickturn CBC and QUEST files
11) STIL (1450.1999 IEEE Standard Test Interface Language) files
12) HP-3070 PCF files
13) Vtran-generated Teradyne Catalyst files
14) Vtran-generated Teradyne J750 files
15) Vtran-generated Teradyne J973 files
16) Vtran-generated Credence SWAV files
17) Vtran-generated Agilent (HP)93000 files
    kermit
wgl to vcd
Thanks! It helps me, but it isnot a free tool !!!
wgl pattern
hi!
that is interesting for my
can vtrans generate an image?
wgl pattern format
I would also like to get some help on how I can approach writing a tool to convert
.vcd files to tester formats like .wgl or .tp. I promise to post the tool once I am
done with it for everyone's use.
wgl to vcd conveter
Anything update ?
vcd pattern
Nothing yet! No one seems to know anything about this!
pattern file, vcd format
Credence tool TDS can do this. But It's not free too.
wgl format description
So anybody? Any help?
how to transfer to vcd pattern
Hello,
I'm developing pattern convertor module which translate VCD into WGL.
Send me your vcd file and I'll convert it.
Regards,
Moez
Re: wgl pattern format
I would like to work with you on the tool.
Thanks
