I'll give you a hint and you figure out what you should do ok. Look at your sampling frequency i.e. your timer interrupt. Pretty obvious from here, isn't it?
can you be a bit more specific....
If it is a real design, also the clk freq. can be suitably adjusted....may not be applicable always. You can also look for retiming....
