MultiProcessor architecture
raja.bhavanam
Junior Member level 3
how to provide an interface between two processors ....
how the data transfer will happen between those two processors.....
These ebooks might help you!?
Multiprocessor Systems on Chips
Ch4. Architecture of Embedded Microprocessors
Pipelined Processor Farms: Structured Design for Embedded Parallel Systems
there is a method called MMU which will connect the 2 processors with the resources being used u have to use crossbar switches into the design
Hi stransno,
This following link is not available in the forum...if u have can u send it to me
For the data transfer between two processors, if your USART already used for other communication, you can do:
1. Using the SPI mode pins, or
2. If u are not familiar with SPI, just using normal I/O port and write the sample data functions yourself.
