command to save parasitic file from dc compiler
siva_7517
Full Member level 2
dc compiler commands through command prompt
hi,
What is the command line to save the parasitic file (spf) from dc compiler
Thanx
i think there is any command..
you get the netlist from DC..
and imported it to STAR-RCXT where you can extract parastic file. using
certain commands given is user guides...
Added after 2 minutes:
You can generate SDF file if you have read parasitic information. To write out parasitcs from DC, I don't remember such a command.
