How to calculate the required freq for H.264 decoding?
johnli100
Member level 1
I read one paper on the H.264 decoding, and one sentence says: "Using a typical PDA processor, e.g. the Intel PXA270, the required frequency for H.264/AVC decoding for DVB-H is about 420 MHz. (320x240 pixel resolution, 384 kBit/s)"
Can someone tell me how to reach this conclusion? why the required frequency is 420 MHz?
Thanks in advance!
I think it's a experiment number.
Just run the software decoder in PDA to get the number.
first, your vidoe frame frequency, for example, 30f/s or 15f/s, even 9f/s, then you can get the operation number per second should be done by encoder.
For typical processor, it's throughput is available.
From above two result you can get the required frequency.
This is not experiment number, which will be calculated carefully.
Hi Matthew, for this case, how to do the calculation? can you explaint to me? thx
