Fast charger and Ordinary charger difference.??
Naveed Alam
Full Member level 5
in market there are many types of mobile battery chargers,, some are ordinary and some are fast charger,,
i have two chargers the Fast one output is (800mA,5.7V) and slow charger output is (350mA,3.7V)
how they perform fast and slow charging.. and why the mobilecompany don't use fast chargers????
Fast chargers use two ways of making the charging time short: 1. higher than recommended charging current or 2. eliminating certain stages from the charging process; for example, stage 2 from the attached picture ..
"Mobilecompanies" guarantee their products for at least 12 months, so they can't afford to take risks and offer you chargers which potentially can be harmful to batteries ..
Regards,
IanP
HI DEAR
IN FAST CHARGING THE CHEMICAL REACTION IN YOUR MOBILE BATTRIES CAHRGE IN SHORT TIME BECAUSE OF EXECISSIVE AMOUNT OF CURRENT BUT IT MAKES THE BATTERY LIFE SHORTER BECAUSE OF THIS MOBILE COMPANIES USE LOW CURRENT CHARGERS
hi IanP,
ur giagram explains it nicely.. but it is telling that the omission of stage 2 will be applied from the software of the mobile, of its manufacturers. so, this must not be the case.. because the extent to which a battery is charged must be the same(i mean the upper limit of its charging)..
am i right??
Regards
