+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Full Member level 2
    Points: 2,578, Level: 11
    Join Date
    May 2004
    Posts
    144
    Points
    2,578
    Level
    11
    PADs CAM
    Hi all i need to know if PADs can do this,
    Lets say i have a net to route in 4 layer board.
    It goes from Layer 1 to Layer 4, meaning the traces DO NOT run in layer 2 or 3.
    When u cam u will see a dot in layer 2 & Layer 3 with no connectivity.
    So how is it possible to remove the 'dots'/ via in layer 2 & 3.
    other then using Cam TOOLs
    tHANKS aLL
    •   Alt4th April 2006, 10:17
      advertising
  2. #2
    Newbie level 5
    Points: 1,782, Level: 9
    Join Date
    Apr 2003
    Posts
    8
    Points
    1,782
    Level
    9
    Re: PADs CAM
    Layer1 -> via -> Layer4. If you remove it you will break the trace.
  3. #3
    Full Member level 6
    Points: 6,698, Level: 19
    sigint's Avatar
    Join Date
    Jan 2000
    State of total unemployment
    Posts
    360
    Points
    6,698
    Level
    19
    Re: PADs CAM
    Not sure about Pads, but, (assuming layer 2 and 3 are positive layers), almost all PCB design softs have the option to plot without non-functional pads, or you can have the pcb fab shop remove inner-layer non-functional pads - usually via a note on your fab drawing.
    SiGiNT
    •   Alt4th April 2006, 21:38
      advertising
  4. #4
    Newbie level 5
    Join Date
    Apr 2003
    Posts
    8
    Points
    1,782
    Level
    9
    Re: PADs CAM
    "It goes from Layer 1 to Layer 4" -> there is no connection with Layer2 and Layer3 -> there is only dot(s) which is a via(s) between Layer1 and Layer4
  5. #5
    Full Member level 4
    Points: 2,289, Level: 11
    Join Date
    Oct 2004
    Posts
    204
    Points
    2,289
    Level
    11
    Re: PADs CAM
    Yes, in PADS it is possible by steps:
    1. in Setup/Padstacks select Via
    2. Add Via with some name, for example: layers14
    3. Set the diameter of via for inner layers equal to 0
    4. Click Ok
    5. On the PCB drawing choose all vias you need without dots and using Querry/Modify
    change their ViaName to layers14
    That is all
    •   Alt7th April 2006, 10:13
      advertising
  6. #6
    Member level 1
    Points: 2,806, Level: 12
    Join Date
    May 2001
    Posts
    34
    Points
    2,806
    Level
    12
    Re: PADs CAM
    If you use splitmix plane the program delete automatically the pad not used.
    Bye
  7. #7
    Junior Member level 2
    Points: 1,261, Level: 8
    Join Date
    Apr 2006
    Posts
    23
    Points
    1,261
    Level
    8
    Re: PADs CAM
    That should be crazy, you don't want the trace routing on layer 2 & 3, at the same time you want to remove the dot in layer 2 & layer 3, it's impossible, the non-function pad should be remove when cam . If you use via1-4, that should be cause a short that the trace will connect to layer 2 & 3.
