+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Advanced Member level 3
    Points: 7,502, Level: 20
    salma ali bakr's Avatar
    Join Date
    Jan 2006
    Posts
    971
    Points
    7,502
    Level
    20
    tiny verilog question:)
    what does this mean:
    "verilog is an interpretive language"...?
    •   AltAdvertisment
  2. #2
    Advanced Member level 2
    Points: 6,007, Level: 18
    samcheetah's Avatar
    Join Date
    May 2004
    Pakistan
    Posts
    646
    Points
    6,007
    Level
    18
    an interpretive language is one that isnt compiled. like in MATLAB you write the script and then run the script and it runs one line at a time and if there is an error, it stops running. but in C you write your code and then compile, which checks the errors and if there are no errors, the linker gives you the exe file. and then you run the program. so C is a compiled language and MATLAB is an interpretive language. generally compiled languages are faster than interpretive languages
    but im not sure if this statement is correct. infact verilog isnt a computer programming language at all. verilog is a hardware descriptive language and HDLs are quite different from computer programming languages. where did you get this statement from??????
    •   AltAdvertisment
  3. #3
    Advanced Member level 1
    Points: 5,380, Level: 17
    sree205's Avatar
    Join Date
    Mar 2006
    Posts
    454
    Points
    5,380
    Level
    17
    i read that it is so when i was reading up on PLIs.
    http://www.project-veripage.com/history.php
    •   AltAdvertisment
  4. #4
    Newbie level 5
    Points: 1,265, Level: 8
    Join Date
    Mar 2006
    Posts
    10
    Points
    1,265
    Level
    8
    Re: tiny verilog question:)
    verilog is not interpreter based, it is compiled - I think this is a wrong statement - u should send a mail to the author and ask him directly what he meant -
    ag
  5. #5
    Join Date
    Jan 2006
    Posts
    971
    Points
    7,502
    Level
    20
    well, i read in the book of Douglas Smith (HDL chip design)
    i should ask him about that ...right?
    •   AltAdvertisment
  6. #6
    Points: 7,292, Level: 20
    gliss's Avatar
    Join Date
    Apr 2005
    Posts
    692
    Points
    7,292
    Level
    20
    Verilog is not interpreted or compiled. It's a hardware description language. It is up to the simulator how it wants to genreate it's internal representation of the code. Some environments use the platforms native machine code for fast simulation.
