mat_jat
Newbie level 2
need advice and help!!!
hello ! i,m newbie in this forum and vhdl programming...
so i hope somebody can help me to correct my programming and
give me some advice..
i was trying to make a control unit between UART and AES core... i make a little
moddification of the source code that i download from open cores...
bellow is my control unit that i try to write but i don't know how to check that every path receive the data that should receive...plz help me
--Beta version
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
entity final_aes128 is
port(
RxD : in Std_Logic;
TxD : out Std_Logic;
Reset : in STD_LOGIC;
done : out std_logic;
CLK : in STD_LOGIC
end final_aes128;
architecture final_aes128_arch of final_aes128 is
--AES signals
signal AES_start, AES_outrdy, AES_mode,load: std_logic;
signal AES_DataOut : std_logic_vector(127 downto 0);
--signal counter_DataIn, counter_KeyIn : std_logic;
--receive and transmit signal
signal UART_Outrdy, UART_Rx, UART_Tx, UART_Tdone, UART_TbufE : std_logic;
--input AES core signal
signal AES_key: std_logic_vector( 127 downto 0);
signal AES_data: std_logic_vector( 127 downto 0);
signal UART_DataIn, UART_DataOut : std_logic_vector(7 downto 0);
signal En_Encryp : std_logic;
--state signal
signal state : std_logic_vector(3 downto 0);
signal sub_state : std_logic_vector(3 downto 0);
component clk_divider
port (
SysClk : in Std_Logic; -- System Clock
En_Encryp : out Std_Logic; -- Control signal
Reset : in Std_Logic -- reset
end component clk_divider;
component miniUART
port (
DataRdy : out std_logic;
Reset : in Std_Logic; -- Reset input
--CS_N : in Std_Logic;
RD_N : in Std_Logic;
WR_N : in Std_Logic;
RxD : in Std_Logic;--assign pin to W8
TxD : out Std_Logic;--assign pin to D15
TBufE : buffer std_logic;
TDone : out std_logic;
DataIn : in Std_Logic_Vector(7 downto 0);--receive output from AES core
DataOut : out Std_Logic_Vector(7 downto 0));--send data to AES core
end component miniUART;
component aes128_fast
port(
clk : in std_logic;
reset : in std_logic;
start : in std_logic; -- to initiate the encryption/decryption process after loading
mode : in std_logic; -- to select encryption or decryption
load : in std_logic; -- to load the input and keys.
key : in std_logic_vector(127 downto 0);
data_in : in std_logic_vector(127 downto 0);
data_out : out std_logic_vector(127 downto 0);
done : out std_logic );
end component aes128_fast;
begin
U_clkdiv : clk_divider
port map(Clk, En_Encryp, reset);
U_UART : miniUART
port map(UART_outrdy, Clk, reset, UART_Rx, UART_Tx, RxD, TxD,
UART_TBufE, UART_TDone, UART_DataIn, UART_DataOut);
U_AES : aes128_fast
port map(En_Encryp, reset, AES_start, AES_mode, load, AES_key,
AES_data, AES_DataOut, AES_Outrdy);
FSM : process(clk, reset, UART_DataIn, UART_DataOut, UART_Outrdy,
UART_TbufE, UART_TDone,
state, sub_state, AES_key, AES_Data, AES_Outrdy,
AES_DataOut)
-- Status message variables, with "#" as end-of-line character.
begin
if reset = '1' then
state <= X"0";--state
sub_state <= X"0";--substate
UART_Tx <='1';--transfer data bl = '0'
UART_Rx <='1';--trm data bl ='0'
UART_DataIn <= (others => '0');--clear data input uart
AES_data <= (others => '0');
AES_key <= (others => '0');
AES_start <= '0';--start process encrypt/decrypt
AES_mode <='0';--signal mode encrypt/decrypt
done <='0';--from top entity
load <='0';--load key and data
elsif clk'event and clk='1' then
AES_Start <= '0';--disable start encrypt/decrypt
UART_Tx <='1';--signal disable transmit
UART_Rx <='1';--signal disable receive
case state is
-- Standby state, wait for Start bit
when X"0" =>--when state 0
UART_Rx <= '0';--enable read
if UART_Outrdy ='1' then--data ready to read
if UART_DataOut = X"31" then--start byte=1 in Hex
state <= state +1;
done <='0';
elsif UART_DataOut = X"30" then--request status
state <= X"0";--state <= "1101"
done <= '0';
end if;
end if;
when X"1" =>--when state 1
if UART_TBufE ='1' then--check buffer empty
UART_DataIn <= X"31";
UART_Tx <= '0';--enable transmit data
state <= state +1;
end if;
-- Receive PlainText
when X"2" =>
UART_Rx <= '0';--enable receive
load <='1';--loading data
if (UART_Outrdy ='1')then--ready to read
case sub_state is
when X"0" =>--sub_state
AES_data(127 downto 120) <= UART_DataOut;
state <= state + 1;
sub_state <= sub_state +1;
when X"1" =>
AES_data(119 downto 112) <= UART_DataOut;
state <= state + 1;
when X"2" =>
AES_data(111 downto 104) <= UART_DataOut;
state <= state + 1;
when X"3" =>
AES_data(103 downto 96) <= UART_DataOut;
state <= state + 1;
when X"4" =>
AES_data(95 downto 88) <= UART_DataOut;
state <= state + 1;
when X"5" =>
AES_data(87 downto 80) <= UART_DataOut;
state <= state + 1;
when X"6" =>
AES_data(79 downto 72) <= UART_DataOut;
state <= state + 1;
when X"7" =>
AES_data(71 downto 64) <= UART_DataOut;
state <= state + 1;
when X"8" =>
AES_data(63 downto 56) <= UART_DataOut;
state <= state +1;
when X"9" =>
AES_data(55 downto 48) <= UART_DataOut;
state <= state +1;
when X"A" =>
AES_data(47 downto 40) <= UART_DataOut;
state <= state +1;
when X"B" =>
AES_data(39 downto 32) <= UART_DataOut;
state <= state +1;
when X"C" =>
AES_data(31 downto 24) <= UART_DataOut;
state <= state +1;
when X"D" =>
AES_data(23 downto 16) <= UART_DataOut;
state <= state +1;
when X"E" =>
AES_data(15 downto 8) <= UART_DataOut;
state <= state +1;
when X"F" =>
AES_data(7 downto 0) <= UART_DataOut;
state <= X"4";--go to state 4
sub_state <= X"0";
end case;
end if;
--get the next byte of data
when X"3" =>
if UART_TBufE ='1' then--if trnsmit buffer empty
UART_Tx <='0';--enable transmit
UART_DataIn <= UART_DataOut;
state <= X"2";
end if;
when X"4" =>
UART_Tx <='0';
state <= state +1;
end if;
-- Receive Encrypt or Decrypt select code
when X"5" =>
UART_Rx <= '0';
if UART_Dataout = X"31" then
AES_mode <='1';--encrypt
elsif UART_Dataout = X"32" then
AES_mode <='0';--decrypt
end if;
state <= state +1;
end if;
when X"6" =>--transmit mode aes
UART_Tx <='0';
state <= state +1;
end if;
-- Receive Cipher Key
when X"7" =>
UART_Rx <='0';
load <='1';
if (UART_Outrdy ='1') then
case sub_state is
AES_key(127 downto 120) <= UART_DataOut;
state <= state + 1;
when X"1" =>
AES_key(119 downto 112) <= UART_DataOut;
state <= state + 1;
when X"2" =>
AES_key(111 downto 104) <= UART_DataOut;
state <= state + 1;
when X"3" =>
AES_key(103 downto 96) <= UART_DataOut;
state <= state + 1;
when X"4" =>
AES_key(95 downto 88) <= UART_DataOut;
state <= state + 1;
when X"5" =>
AES_key(87 downto 80) <= UART_DataOut;
state <= state + 1;
when X"6" =>
AES_key(79 downto 72) <= UART_DataOut;
state <= state + 1;
when X"7" =>
AES_key(71 downto 64) <= UART_DataOut;
state <= state + 1;
when X"8" =>
AES_key(63 downto 56) <= UART_DataOut;
state <= state +1;
when X"9" =>
AES_key(55 downto 48) <= UART_DataOut;
state <= state +1;
when X"A" =>
AES_key(47 downto 40) <= UART_DataOut;
state <= state +1;
when X"B" =>
AES_key(39 downto 32) <= UART_DataOut;
state <= state +1;
when X"C" =>
AES_key(31 downto 24) <= UART_DataOut;
state <= state +1;
when X"D" =>
AES_key(23 downto 16) <= UART_DataOut;
state <= state +1;
when X"E" =>
AES_key(15 downto 8) <= UART_DataOut;
state <= state +1;
when X"F" =>
AES_key(7 downto 0) <= UART_DataOut;
state <= X"9";--go to state 9
sub_state <= X"0";
end case;
end if;
--get the next byte of key
when X"8" =>
UART_Tx <='0';
state <= X"7";
end if;
when X"9" =>--state 9
if UART_TBufE ='1' then--transmit buffer kosong
AES_start <='1';--start encrypt/decrypt
state <= state +1;
end if;
-- Cipher done, transmit CipherText out
when X"A" =>--state 10
if (UART_TBufE ='1' and AES_Outrdy='1') then-- aes_outready
UART_Tx <='0';
case sub_state is
when X"0" =>
UART_DataIn <= AES_DataOut(127 downto 120);
state <= state +1;
when X"1" =>
UART_DataIn <= AES_DataOut(119 downto 112);
state <= state +1;
when X"2" =>
UART_DataIn <= AES_DataOut(111 downto 104);
state <= state +1;
when X"3" =>
UART_DataIn <= AES_DataOut(103 downto 96);
state <= state +1;
when X"4" =>
UART_DataIn <= AES_DataOut(95 downto 88);
state <= state +1;
when X"5" =>
UART_DataIn <= AES_DataOut(87 downto 80);
state <= state +1;
when X"6" =>
UART_DataIn <= AES_DataOut(79 downto 72);
state <= state +1;
when X"7" =>
UART_DataIn <= AES_DataOut(71 downto 64);
state <= state +1;
when X"8" =>
UART_DataIn <= AES_DataOut(63 downto 56);
state <= state +1;
when X"9" =>
UART_DataIn <= AES_DataOut(55 downto 48);
state <= state +1;
when X"A" =>
UART_DataIn <= AES_DataOut(47 downto 40);
state <= state +1;
when X"B" =>
UART_DataIn <= AES_DataOut(39 downto 32);
state <= state +1;
when X"C" =>
UART_DataIn <= AES_DataOut(31 downto 24);
state <= state +1;
when X"D" =>
UART_DataIn <= AES_DataOut(23 downto 16);
state <= state +1;
when X"E" =>
UART_DataIn <= AES_DataOut(15 downto 8);
state <= state +1;
when X"F" =>
UART_DataIn <= AES_DataOut(7 downto 0);
state <= X"C";
sub_state <= X"0";
end case;
end if;
when X"B" =>--state11
if UART_TbufE ='0' then--transmit not ready
state <= X"A";-- repeat transmit
end if;
when X"C" =>--
state <= X"0"; -- repeat
done <='1';--complete transmit
when others => null;
end case;
end if;
end process FSM;
end final_aes128_arch;
this is my top entity program...
--Beta version
library IEEE;
port(
RxD : in Std_Logic;
CLK : in STD_LOGIC
end final_aes128;
--AES signals
--state signal
port (
component miniUART
port (
port(
clk : in std_logic;
begin
U_UART : miniUART
U_AES : aes128_fast
AES_DataOut)
begin
if reset = '1' then
case state is
state <= state +1;
done <='0';
done <= '0';
end if;
end if;
state <= state +1;
end if;
when X"2" =>
case sub_state is
state <= state + 1;
when X"1" =>
state <= state + 1;
when X"2" =>
state <= state + 1;
when X"3" =>
state <= state + 1;
when X"4" =>
state <= state + 1;
when X"5" =>
state <= state + 1;
when X"6" =>
state <= state + 1;
when X"7" =>
state <= state + 1;
when X"8" =>
state <= state +1;
when X"9" =>
state <= state +1;
when X"A" =>
state <= state +1;
when X"B" =>
state <= state +1;
when X"C" =>
state <= state +1;
when X"D" =>
state <= state +1;
when X"E" =>
state <= state +1;
when X"F" =>
sub_state <= X"0";
end case;
end if;
when X"3" =>
state <= X"2";
end if;
when X"4" =>
UART_Tx <='0';
state <= state +1;
end if;
when X"5" =>
UART_Rx <= '0';
end if;
state <= state +1;
end if;
UART_Tx <='0';
state <= state +1;
end if;
when X"7" =>
UART_Rx <='0';
load <='1';
case sub_state is
state <= state + 1;
when X"1" =>
state <= state + 1;
when X"2" =>
state <= state + 1;
when X"3" =>
state <= state + 1;
when X"4" =>
state <= state + 1;
when X"5" =>
state <= state + 1;
when X"6" =>
state <= state + 1;
when X"7" =>
state <= state + 1;
when X"8" =>
state <= state +1;
when X"9" =>
state <= state +1;
when X"A" =>
state <= state +1;
when X"B" =>
state <= state +1;
when X"C" =>
state <= state +1;
when X"D" =>
state <= state +1;
when X"E" =>
state <= state +1;
when X"F" =>
sub_state <= X"0";
end case;
end if;
when X"8" =>
UART_Tx <='0';
state <= X"7";
end if;
state <= state +1;
end if;
UART_Tx <='0';
case sub_state is
when X"0" =>
state <= state +1;
when X"1" =>
state <= state +1;
when X"2" =>
state <= state +1;
when X"3" =>
state <= state +1;
when X"4" =>
state <= state +1;
when X"5" =>
state <= state +1;
when X"6" =>
state <= state +1;
when X"7" =>
state <= state +1;
when X"8" =>
state <= state +1;
when X"9" =>
state <= state +1;
when X"A" =>
state <= state +1;
when X"B" =>
state <= state +1;
when X"C" =>
state <= state +1;
when X"D" =>
state <= state +1;
when X"E" =>
state <= state +1;
when X"F" =>
state <= X"C";
sub_state <= X"0";
end case;
end if;
end if;
when X"C" =>--
end case;
end if;
end process FSM;
