Help me with the code for control unit UART&AES core (VH
mat_jat
Newbie level 2
need advice and help!!!
hello ! i,m newbie in this forum and vhdl programming...
so i hope somebody can help me to correct my programming and
give me some advice..
i was trying to make a control unit between UART and AES core... i make a little
moddification of the source code that i download from open cores...
bellow is my control unit that i try to write but i don't know how to check that every path receive the data that should receive...plz help me
--Beta version
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
entity final_aes128 is
port(
RxD : in Std_Logic;
TxD : out Std_Logic;
Reset : in STD_LOGIC;
done : out std_logic;
CLK : in STD_LOGIC
end final_aes128;
architecture final_aes128_arch of final_aes128 is
--AES signals
signal AES_start, AES_outrdy, AES_mode,load: std_logic;
signal AES_DataOut : std_logic_vector(127 downto 0);
--signal counter_DataIn, counter_KeyIn : std_logic;
--receive and transmit signal
signal UART_Outrdy, UART_Rx, UART_Tx, UART_Tdone, UART_TbufE : std_logic;
--input AES core signal
signal AES_key: std_logic_vector( 127 downto 0);
signal AES_data: std_logic_vector( 127 downto 0);
signal UART_DataIn, UART_DataOut : std_logic_vector(7 downto 0);
signal En_Encryp : std_logic;
--state signal
signal state : std_logic_vector(3 downto 0);
signal sub_state : std_logic_vector(3 downto 0);
component clk_divider
port (
SysClk : in Std_Logic; -- System Clock
En_Encryp : out Std_Logic; -- Control signal
Reset : in Std_Logic -- reset
end component clk_divider;
component miniUART
port (
DataRdy : out std_logic;
Reset : in Std_Logic; -- Reset input
--CS_N : in Std_Logic;
RD_N : in Std_Logic;
WR_N : in Std_Logic;
RxD : in Std_Logic;--assign pin to W8
TxD : out Std_Logic;--assign pin to D15
TBufE : buffer std_logic;
TDone : out std_logic;
DataIn : in Std_Logic_Vector(7 downto 0);--receive output from AES core
DataOut : out Std_Logic_Vector(7 downto 0));--send data to AES core
end component miniUART;
component aes128_fast
port(
clk : in std_logic;
reset : in std_logic;
start : in std_logic; -- to initiate the encryption/decryption process after loading
mode : in std_logic; -- to select encryption or decryption
load : in std_logic; -- to load the input and keys.
key : in std_logic_vector(127 downto 0);
data_in : in std_logic_vector(127 downto 0);
data_out : out std_logic_vector(127 downto 0);
done : out std_logic );
end component aes128_fast;
begin
U_clkdiv : clk_divider
port map(Clk, En_Encryp, reset);
U_UART : miniUART
port map(UART_outrdy, Clk, reset, UART_Rx, UART_Tx, RxD, TxD,
UART_TBufE, UART_TDone, UART_DataIn, UART_DataOut);
U_AES : aes128_fast
port map(En_Encryp, reset, AES_start, AES_mode, load, AES_key,
AES_data, AES_DataOut, AES_Outrdy);
FSM : process(clk, reset, UART_DataIn, UART_DataOut, UART_Outrdy,
UART_TbufE, UART_TDone,
state, sub_state, AES_key, AES_Data, AES_Outrdy,
AES_DataOut)
-- Status message variables, with "#" as end-of-line character.
begin
if reset = '1' then
state <= X"0";--state
sub_state <= X"0";--substate
UART_Tx <='1';--transfer data bl = '0'
UART_Rx <='1';--trm data bl ='0'
UART_DataIn <= (others => '0');--clear data input uart
AES_data <= (others => '0');
AES_key <= (others => '0');
AES_start <= '0';--start process encrypt/decrypt
AES_mode <='0';--signal mode encrypt/decrypt
done <='0';--from top entity
load <='0';--load key and data
elsif clk'event and clk='1' then
AES_Start <= '0';--disable start encrypt/decrypt
UART_Tx <='1';--signal disable transmit
UART_Rx <='1';--signal disable receive
case state is
-- Standby state, wait for Start bit
when X"0" =>--when state 0
UART_Rx <= '0';--enable read
if UART_Outrdy ='1' then--data ready to read
if UART_DataOut = X"31" then--start byte=1 in Hex
state <= state +1;
done <='0';
elsif UART_DataOut = X"30" then--request status
state <= X"0";--state <= "1101"
done <= '0';
end if;
end if;
when X"1" =>--when state 1
if UART_TBufE ='1' then--check buffer empty
UART_DataIn <= X"31";
UART_Tx <= '0';--enable transmit data
state <= state +1;
end if;
-- Receive PlainText
when X"2" =>
UART_Rx <= '0';--enable receive
load <='1';--loading data
if (UART_Outrdy ='1')then--ready to read
case sub_state is
when X"0" =>--sub_state
AES_data(127 downto 120) <= UART_DataOut;
state <= state + 1;
sub_state <= sub_state +1;
when X"1" =>
AES_data(119 downto 112) <= UART_DataOut;
state <= state + 1;
when X"2" =>
AES_data(111 downto 104) <= UART_DataOut;
state <= state + 1;
when X"3" =>
AES_data(103 downto 96) <= UART_DataOut;
state <= state + 1;
when X"4" =>
AES_data(95 downto 88) <= UART_DataOut;
state <= state + 1;
when X"5" =>
AES_data(87 downto 80) <= UART_DataOut;
state <= state + 1;
when X"6" =>
AES_data(79 downto 72) <= UART_DataOut;
state <= state + 1;
when X"7" =>
AES_data(71 downto 64) <= UART_DataOut;
state <= state + 1;
when X"8" =>
AES_data(63 downto 56) <= UART_DataOut;
state <= state +1;
when X"9" =>
AES_data(55 downto 48) <= UART_DataOut;
state <= state +1;
when X"A" =>
AES_data(47 downto 40) <= UART_DataOut;
state <= state +1;
when X"B" =>
AES_data(39 downto 32) <= UART_DataOut;
state <= state +1;
when X"C" =>
AES_data(31 downto 24) <= UART_DataOut;
state <= state +1;
when X"D" =>
AES_data(23 downto 16) <= UART_DataOut;
state <= state +1;
when X"E" =>
AES_data(15 downto 8) <= UART_DataOut;
state <= state +1;
when X"F" =>
AES_data(7 downto 0) <= UART_DataOut;
state <= X"4";--go to state 4
sub_state <= X"0";
end case;
end if;
--get the next byte of data
when X"3" =>
if UART_TBufE ='1' then--if trnsmit buffer empty
UART_Tx <='0';--enable transmit
UART_DataIn <= UART_DataOut;
state <= X"2";
end if;
when X"4" =>
UART_Tx <='0';
state <= state +1;
end if;
-- Receive Encrypt or Decrypt select code
when X"5" =>
UART_Rx <= '0';
if UART_Dataout = X"31" then
AES_mode <='1';--encrypt
elsif UART_Dataout = X"32" then
AES_mode <='0';--decrypt
end if;
state <= state +1;
end if;
when X"6" =>--transmit mode aes
UART_Tx <='0';
state <= state +1;
end if;
-- Receive Cipher Key
when X"7" =>
UART_Rx <='0';
load <='1';
if (UART_Outrdy ='1') then
case sub_state is
AES_key(127 downto 120) <= UART_DataOut;
state <= state + 1;
when X"1" =>
AES_key(119 downto 112) <= UART_DataOut;
state <= state + 1;
when X"2" =>
AES_key(111 downto 104) <= UART_DataOut;
state <= state + 1;
when X"3" =>
AES_key(103 downto 96) <= UART_DataOut;
state <= state + 1;
when X"4" =>
AES_key(95 downto 88) <= UART_DataOut;
state <= state + 1;
when X"5" =>
AES_key(87 downto 80) <= UART_DataOut;
state <= state + 1;
when X"6" =>
AES_key(79 downto 72) <= UART_DataOut;
state <= state + 1;
when X"7" =>
AES_key(71 downto 64) <= UART_DataOut;
state <= state + 1;
when X"8" =>
AES_key(63 downto 56) <= UART_DataOut;
state <= state +1;
when X"9" =>
AES_key(55 downto 48) <= UART_DataOut;
state <= state +1;
when X"A" =>
AES_key(47 downto 40) <= UART_DataOut;
state <= state +1;
when X"B" =>
AES_key(39 downto 32) <= UART_DataOut;
state <= state +1;
when X"C" =>
AES_key(31 downto 24) <= UART_DataOut;
state <= state +1;
when X"D" =>
AES_key(23 downto 16) <= UART_DataOut;
state <= state +1;
when X"E" =>
AES_key(15 downto 8) <= UART_DataOut;
state <= state +1;
when X"F" =>
AES_key(7 downto 0) <= UART_DataOut;
state <= X"9";--go to state 9
sub_state <= X"0";
end case;
end if;
--get the next byte of key
when X"8" =>
UART_Tx <='0';
state <= X"7";
end if;
when X"9" =>--state 9
if UART_TBufE ='1' then--transmit buffer kosong
AES_start <='1';--start encrypt/decrypt
state <= state +1;
end if;
-- Cipher done, transmit CipherText out
when X"A" =>--state 10
if (UART_TBufE ='1' and AES_Outrdy='1') then-- aes_outready
UART_Tx <='0';
case sub_state is
when X"0" =>
UART_DataIn <= AES_DataOut(127 downto 120);
state <= state +1;
when X"1" =>
UART_DataIn <= AES_DataOut(119 downto 112);
state <= state +1;
when X"2" =>
UART_DataIn <= AES_DataOut(111 downto 104);
state <= state +1;
when X"3" =>
UART_DataIn <= AES_DataOut(103 downto 96);
state <= state +1;
when X"4" =>
UART_DataIn <= AES_DataOut(95 downto 88);
state <= state +1;
when X"5" =>
UART_DataIn <= AES_DataOut(87 downto 80);
state <= state +1;
when X"6" =>
UART_DataIn <= AES_DataOut(79 downto 72);
state <= state +1;
when X"7" =>
UART_DataIn <= AES_DataOut(71 downto 64);
state <= state +1;
when X"8" =>
UART_DataIn <= AES_DataOut(63 downto 56);
state <= state +1;
when X"9" =>
UART_DataIn <= AES_DataOut(55 downto 48);
state <= state +1;
when X"A" =>
UART_DataIn <= AES_DataOut(47 downto 40);
state <= state +1;
when X"B" =>
UART_DataIn <= AES_DataOut(39 downto 32);
state <= state +1;
when X"C" =>
UART_DataIn <= AES_DataOut(31 downto 24);
state <= state +1;
when X"D" =>
UART_DataIn <= AES_DataOut(23 downto 16);
state <= state +1;
when X"E" =>
UART_DataIn <= AES_DataOut(15 downto 8);
state <= state +1;
when X"F" =>
UART_DataIn <= AES_DataOut(7 downto 0);
state <= X"C";
sub_state <= X"0";
end case;
end if;
when X"B" =>--state11
if UART_TbufE ='0' then--transmit not ready
state <= X"A";-- repeat transmit
end if;
when X"C" =>--
state <= X"0"; -- repeat
done <='1';--complete transmit
when others => null;
end case;
end if;
end process FSM;
end final_aes128_arch;
this is my top entity program...
Re: need advice and help!!!
first of all you must do identination to your code.
second of all you only need to put clk, reset in the sensitivity list of the fsm.
thanx for reply!!
so you mean that i need to put clk and reset only into a fsm state that sensitive to both of it...i will try...
