3d image of a pcb from pads
Rame
Full Member level 6
BANGALORE
pads export idf
Hi Folks,
Can anyone guide me in taking 3d image of a layout design from pads 2004?
Help me to proceed on this issue......
Advance thanx.
Ramesh
pcb 3d image
well, try dxf out. You can try import it & view in mechanical softwares like PRO-E or solid works.
Good Luck.
mentor pads idf
from pads layout export to idf, then import into solidworks
1. export DXF file format
2. Use one of the following softwares:
A. AutoCad
B. Solid Works
C. 3DsMAX
In general all 3d softwares out there use a DXF File format.
the question is which 3D software is easy and fast to use
I don't use Pads, so I don't know the answer to this. Does the exported DXF file contain Z-Axis data? I export DXF out of Mentor Expedition all of the time, but I have only looked at the files in AutoCad LT, which is only 2-D
If Pads can export IDF and you have a tool that supports it (Pro-E, Solid Works), that would be the best solution.
