Commenting on system stability when given transfer function of a discrete system
neils_arm_strong
Full Member level 5
Bangalore, India
Given a tranfer function of a discrete system in terms of Z,how to comment on the stability of the system?
Re: system stabilty
neils_arm_strong,
Calculate the values of the poles (roots of the denominator). If they are all inside the unit circle, the system is stable. The closer the poles are to the unit circle, the more oscillitory the response will be.
Regards,
Kral
Re: system stabilty
if you don't know the ROC, it is generally impossible to say about stability. a transfer function may correspond to some stable and/or unstable functions.
system stabilty
Given the the Region of Convergence (RoC) covers the unit circle, then the function is stable.
The pictures towards the bottom are quite helpful.
