Results 1 to 2 of 2
    Member level 5
    Points: 1,909, Level: 10
    Nov 2005
    82
    1,909
    10
    matlab polar axis
    Hi, I have a simple question about MATLAB function "polar". Are there any command like "xlim" in plot to change the plot's radius axis limit? Thanks
    Newbie level 1
    Points: 1,237, Level: 7
    Jan 2006
    1,237
    7
    matlab polar plot axis
    Hello Jay,
    today I have had the same problem,
    somewhere in the matlab source directories I found the original "polar.m"
    function. I copied it to my matlab home directory as a new function polarmy.m
    with more input variables (and I added 2-3 lines marked by the word 'attention')
    example:
    if you call : polarmy(theta,rho,'-',60,3)
    circles will be drawn at rho=0, 20, 40, 60
    Maybe it is enough for you too. However I cannot give you any warranty for this routine.
    Bye,
    Klemens
    function hpol = polarmy(theta,rho,line_style,rmaxx,rtick)
    %POLAR Polar coordinate plot.
    % POLAR(THETA, RHO) makes a plot using polar coordinates of
    % the angle THETA, in radians, versus the radius RHO.
    % POLAR(THETA,RHO,S) uses the linestyle specified in string S.
    % See PLOT for a description of legal linestyles.
    % See also PLOT, LOGLOG, SEMILOGX, SEMILOGY.
    % Copyright 1984-2002 The MathWorks, Inc.
    % $Revision: 5.22 $ $Date: 2002/04/08 21:44:28 $
    if nargin < 1
    error('Requires 2 or 3 input arguments.')
    elseif nargin == 2
    if isstr(rho)
    line_style = rho;
    rho = theta;
    [mr,nr] = size(rho);
    if mr == 1
    theta = 1:nr;
    else
    th = (1:mr)';
    theta = th(:,ones(1,nr));
    end
    else
    line_style = 'auto';
    end
    elseif nargin == 1
    rho = theta;
    if mr == 1
    theta = 1:nr;
    else
    th = (1:mr)';
    end
    end
    if isstr(theta) | isstr(rho)
    error('Input arguments must be numeric.');
    end
    if ~isequal(size(theta),size(rho))
    error('THETA and RHO must be the same size.');
    end
    % get hold state
    cax = newplot;
    next = lower(get(cax,'NextPlot'));
    hold_state = ishold;
    % get x-axis text color so grid is in same color
    tc = get(cax,'xcolor');
    ls = get(cax,'gridlinestyle');
    % Hold on to current Text defaults, reset them to the
    % Axes' font attributes so tick marks use them.
    fAngle = get(cax, 'DefaultTextFontAngle');
    fName = get(cax, 'DefaultTextFontName');
    fSize = get(cax, 'DefaultTextFontSize');
    fWeight = get(cax, 'DefaultTextFontWeight');
    fUnits = get(cax, 'DefaultTextUnits');
    set(cax, 'DefaultTextFontAngle', get(cax, 'FontAngle'), ...
    'DefaultTextFontName', get(cax, 'FontName'), ...
    'DefaultTextFontSize', get(cax, 'FontSize'), ...
    'DefaultTextFontWeight', get(cax, 'FontWeight'), ...
    'DefaultTextUnits','data')
    % only do grids if hold is off
    if ~hold_state
    % make a radial grid
    hold on;
    maxrho = max(abs(rho(:)));
    hhh=plot([-maxrho -maxrho maxrho maxrho],[-maxrho maxrho maxrho -maxrho]);
    set(gca,'dataaspectratio',[1 1 1],'plotboxaspectratiomode','auto')
    v = [get(cax,'xlim') get(cax,'ylim')];
    ticks = sum(get(cax,'ytick')>=0);
    delete(hhh);
    % check radial limits and ticks
    rmin = 0; rmax = v(4); rticks = max(ticks-1,2);
    if rticks > 5 % see if we can reduce the number
    if rem(rticks,2) == 0
    rticks = rticks/2;
    elseif rem(rticks,3) == 0
    rticks = rticks/3;
    end
    end
    % attention I added these lines
    % rtick and rmax are new function inputs
    rticks=rtick*2;
    rmax=rmaxx;
    rmin=-rmax;
    % define a circle
    th = 0:pi/50:2*pi;
    xunit = cos(th);
    yunit = sin(th);
    % now really force points on x/y axes to lie on them exactly
    inds = 1:(length(th)-1)/4:length(th);
    xunit(inds(2:2:4)) = zeros(2,1);
    yunit(inds(1:2:5)) = zeros(3,1);
    % plot background if necessary
    if ~isstr(get(cax,'color')),
    patch('xdata',xunit*rmax,'ydata',yunit*rmax, ...
    'edgecolor',tc,'facecolor',get(gca,'color'),...
    'handlevisibility','off');
    end
    % draw radial circles
    c82 = cos(82*pi/180);
    s82 = sin(82*pi/180);
    rinc = (rmax-rmin)/rticks;
    for i=(rmin+rinc):rinc:rmax
    hhh = plot(xunit*i,yunit*i,ls,'color',tc,'linewidth',1,. ..
    text((i+rinc/20)*c82,(i+rinc/20)*s82, ...
    [' ' num2str(i)],'verticalalignment','bottom',...
    end
    set(hhh,'linestyle','-') % Make outer circle solid
    % plot spokes
    th = (1:6)*2*pi/12;
    cst = cos(th); snt = sin(th);
    cs = [-cst; cst];
    sn = [-snt; snt];
    plot(rmax*cs,rmax*sn,ls,'color',tc,'linewidth',1,. ..
    % annotate spokes in degrees
    rt = 1.1*rmax;
    for i = 1:length(th)
    text(rt*cst(i),rt*snt(i),int2str(i*30),...
    'horizontalalignment','center',...
    if i == length(th)
    loc = int2str(0);
    else
    loc = int2str(180+i*30);
    end
    text(-rt*cst(i),-rt*snt(i),loc,'horizontalalignment','center',...
    end
    % set view to 2-D
    view(2);
    % set axis limits
    axis(rmax*[-1 1 -1.15 1.15]);
    end
    % Reset defaults.
    set(cax, 'DefaultTextFontAngle', fAngle , ...
    'DefaultTextFontName', fName , ...
    'DefaultTextFontSize', fSize, ...
    'DefaultTextFontWeight', fWeight, ...
    'DefaultTextUnits',fUnits );
    % transform data to Cartesian coordinates.
    xx = rho.*cos(theta);
    yy = rho.*sin(theta);
    % plot data on top of grid
    if strcmp(line_style,'auto')
    q = plot(xx,yy);
    else
    q = plot(xx,yy,line_style);
    end
    if nargout > 0
    hpol = q;
    end
    if ~hold_state
    set(gca,'dataaspectratio',[1 1 1]), axis off; set(cax,'NextPlot',next);
    end
    set(get(gca,'xlabel'),'visible','on')
    set(get(gca,'ylabel'),'visible','on')
