Find delay, in Simulink BPSK simulation
Antonio_Magma
Full Member level 2
bpsk simulink
I'm simulation BPSK with Convolutional Encoding in Simulink. I use the Error Rate Calculation block to calculate the delay between Tx and Rx.
The error rate block contains a recieve delay parameter which has to be inserted with the value of the delay between its 2 inputs. I used the Find delay block to find the delay between Tx and Rx, however i can't get a fixed value. The value keeps on fluctuating.
From the help of Simulink, it says that if the delay value fluctuates means that i have to set the windowing value of the Find delay block to a higher value. However, i've tried various values of windowing, up to 1000 yet i still can't find the correct delay value to be inserted into the error rate block...
Without the delay parameter, i'm getting incorrect error rates of up to 0.5
Please help!!
