ulaska
Member level 3
Please can you give some information about this issue?
- Which values of Caps must we put near the ICs in HI / LOw frequencies.?
- Which values of Caps must we put for board de-coupling ?
- Which values of Caps and L s (beads etc. ) must we use between Analog VCC and Digital VCC, also between Analog GND and Digital GND? in high and low frequencies?
for example, on a board that runs in 50 MHz, can i use 100nF for board de-coupling and 100nFs for ICs near VCC pins ? and what value of Bead can i use between the AVCC and DVCC ?
Thanks
Thanks
