+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Full Member level 3
    Points: 2,517, Level: 11
    Join Date
    Aug 2005
    Posts
    175
    Points
    2,517
    Level
    11
    RF choke, why not turned-off MOS?
    Why we don't use a turned-off mosfet to be the rf choke, it provides
    very large resistance and small parasitics for rf application. But we rarely see
    this, why?
  2. #2
    Advanced Member level 5
    Points: 34,356, Level: 45
    Join Date
    Dec 2004
    New England, USA
    Posts
    4,820
    Points
    34,356
    Level
    45
    Re: RF choke, why not turned-off MOS?
    Gee, that is a great idea. Next time you need an RF choke that has extremely high dc resistance, feel free to use it!
    •   AltAdvertisement
  3. #3
    Full Member level 4
    Points: 3,032, Level: 12
    Join Date
    Nov 2004
    Posts
    194
    Points
    3,032
    Level
    12
    But how about the settling time constant, while you power down or power up
    your circuit.
  4. #4
    Advanced Member level 2
    Points: 5,822, Level: 18
    Join Date
    Mar 2002
    Posts
    509
    Points
    5,822
    Level
    18
    RF Chokes are meant to have Very High RF impedance and
    no DC impedance. They also need to be able to handle any
    where from 1mA to 10 Amps of current.
    An Inductor it the perfect candidate.
    •   AltAdvertisement
  5. #5
    Full Member level 3
    Join Date
    Aug 2005
    Posts
    175
    Points
    2,517
    Level
    11
    If you connect a rf choke to a gate of mos, it needn't to handle the dc current.
  6. #6
    Full Member level 2
    Points: 3,081, Level: 13
    dsjomo's Avatar
    Join Date
    Oct 2003
    Taiwan
    Posts
    149
    Points
    3,081
    Level
    13
    If there is no inversion layer in the channel, the DC bias of the substrate is equal to GND, so it is impossible to conduct the VB to RF_IN.
  7. #7
    Full Member level 4
    Join Date
    Nov 2004
    Posts
    194
    Points
    3,032
    Level
    12
    The Vb still can conduc to RF_in because of the leakage current. It's not really infinite
    ohms when a transistor turned of. It may be around Gohms.
    •   AltAdvertisement
  8. #8
    Full Member level 3
    Join Date
    Aug 2005
    Posts
    175
    Points
    2,517
    Level
    11
    Quote Originally Posted by hebu
    The voltage conducted to RF_in is divided by two huge resistors, one is the
    turned- off channel, and the other one is reversed p-n juction. So, we need
    to make sure the resistance of channel is smaller enough than junction
    resistance.
  9. #9
    Full Member level 6
    Points: 5,173, Level: 17
    Join Date
    Feb 2004
    NE USA
    Posts
    372
    Points
    5,173
    Level
    17
    What is the advantage of an turned off MOS over a RF Choke? Can you get stand alone MOS devices to put in a power supply line? How much does it cost? How about static zaps?
    There are hundreds of ways to do an arbitrary design task. If you are proposing a new way to do something, there should be advantages that you can enumerate. Just because you can do something doesn't mean that you should.
    Dave
