float to fixed point conversion function
omara007
Cairo/Egypt
guys ..
anyone has a function to convert real/float numbers to fixed point with a given precision ?
for example : I give the function this number : (0.5) as a first argument and in the second argument I give it (1) as the number of binary digits to the left of the binary point , and (2) in the third argument as the number of binary digits to the right of the binary point.
The return value will be (010)
if the function is called funcX => funcX(0.75,1,2) returns (011)
and so on ..
functions in matlab, vhdl, c are all welcomed ..
AA,
I think it is meaning less to give the required bits to represent the digits left to the radix point. What if you passed a number not sufficient to represent the that number? Will it discard the least or most significant bits?
By the way this function can be easly done.
Regards,
Amr.
There are some concepts that you maybe missing like overflow .. saturation ..
The function can saturate to its ceiling .. or simply assert an overflow flag ..
If you are close to the hardware architecture , u wouldn't have said so. Simply becuase if you go for design, you will be restricted in certain vector length where u have to shrink your data to fit in or make some work arounds ..
AA,
Be sure that I do not miss these concepts. But you did not specify these requirements in ur original message. you said u will specify the required bit width, so the function should overcome all possible values permited by software or hardware, whatever.
Functions with variable parameters cannot be synthesized, if you are targetting hardware. You can model them only.
Finally,
I am glad to help if necessary.
Regards,
Amr.
Plz check documentation for "round", "floor", "ceil" and "fix" in MATLAB.These are built-in functions there scripts are not availble
I know these functions and they don't convert to fixed point in binary format .. the 4 of them are completely rounding functions and has nothing to do with floating/fixed point things ..
U can use them & write ur conevrsion functions for the extracted parts.
Regards,
Amr.
guys ..
the problem is not at all in ceinling/flooring .. am asking about a float to fixed standard function available in any language .. no more no less ..
