data communication by computer
Noman Yousaf
Full Member level 4
Lahore Pakistan
i want to interface the AT89C51 with computer either by serial or perellal port
i know Assambly lang.
i want to make the display on computer monitor which must show the number of pulses or data come from mcu.
or any readymade software which can do the required thing.
i can use rs232 too.
send this no. on UART in the correct format you want to display. Use hyper terminal to view this.
note:-In hyper terminal ascii values are printed only so you have to convrt it into ascii and send each digit saperately
HELLO THIS ASSEMPLY FILE DISPLAYES "AHMED" IN 9600 n-8-1 SERIAL COMMMUNICATION
#INCLUDE "8051EQU.INC"
; RESET                         ;reset routine
   .ORG   0H                    ;locate routine at 00H
    AJMP   START                ;jump to START
; INTERRUPTS  (not used)        ;place interrupt routines at appropriate
                                ;memory locations
   .ORG   03H                   ;external interrupt 0
    RETI
   .ORG   0BH                   ;timer 0 interrupt
    RETI
   .ORG   13H                   ;external interrupt 1
    RETI
   .ORG   1BH                   ;timer 1 interrupt
    RETI
   .ORG   23H                   ;serial port interrupt
    RETI
   .ORG   25H                   ;locate beginning of rest of program
INITIALIZE:                     ;set up control registers
    MOV   TCON,#00H
    MOV   TMOD,#00H
    MOV   PSW,#00H
    MOV   IE,#00H               ;disable interrupts
    RET
;      Real code starts below. The first two routines are for delays so we
;      can slow down the blinking so we can see it. (Without a delay, it
;      would blink so fast it would look like it was always on.
DELAYMS:                        ;millisecond delay routine
   MOV   R7,#00H                ;put value of 0 in register R7
LOOPA:
   INC   R7                     ;increase R7 by one (R7 = R7 +1)
   MOV   A,R7                   ;move value in R7 to Accumlator (also known as A)
   CJNE   A,#0FFH,LOOPA         ;compare A to FF hex (256). If not equal go to LOOPA
   RET                          ;return to the point that this routine was called from
DELAYHS:                        ;half second delay above millisecond delay
   MOV   R6,#00H                ;put 0 in register R6 (R6 = 0)
   MOV   R5,#002H               ;put 2 in register R5 (R5 = 2)
LOOPB:
   INC   R6                     ;increase R6 by one (R6 = R6 +1)
   ACALL   DELAYMS              ;call the routine above. It will run and return to here.
   MOV   A,R6                   ;move value in R6 to A
   JNZ   LOOPB                  ;if A is not 0, go to LOOPB
   DEC   R5                     ;decrease R5 by one. (R5 = R5 -1)
   MOV   A,R5                   ;move value in R5 to A
   JNZ   LOOPB                  ;if A is not 0 then go to LOOPB.
   RET
START:                          ;main program (on power up, program starts at this point)
   ACALL INITIALIZE             ;set up control registers
	MOV TMOD,#20H
	MOV TCON,#41H
	MOV TH1,#0FDH
	MOV SCON,#50H
LOOP:
;   CPL P1.1                     ;ComPLement (invert) P1.0 (this makes LED change)
;   ACALL DELAYHS                ;go to above routine that causes a delay
   CLR TI
   MOV SBUF,#'A'
   JNB TI,$
   CLR TI
   MOV SBUF,#'H'
   JNB TI,$
   CLR TI
   MOV SBUF,#'M'
   JNB TI,$
   CLR TI
   MOV SBUF,#'E'
   JNB TI,$
   CLR TI
   MOV SBUF,#'D'
   JNB TI,$
   CLR TI
   MOV SBUF,#' '
   JNB TI,$
   CLR TI
   MOV SBUF,#13
   JNB TI,$
   CLR TI
   MOV SBUF,#10
   JNB TI,$
   AJMP LOOP                    ;go to LOOP(always jump back to point labeled LOOP)
.END                            ;end program
thanks i know how to check the data from hyper termianl but i want to see tha coming data like whe pulses r come, a counter is displayed which shows the counter digits or so on
it could be done by LPT port
