Will Windows create virtual COM for FT245 ?
aldevan
Full Member level 2
São Paulo - Brazil
ft245
hi, I use ftdi ft232bm to converter usb to serial rs232 and when a plug it in my computer usb port the sistem creat a virtual COM, ex: COM5, my question is what windows will creat if a plug a ft245? is a virtual COM too?
FT245
The FT245 and FT232 are similar from win point of view, they are using the same drivers. FT245 will create a serial port, as for FT232, if you are using the VCOMM drivers. Also, the behaviour is similar if you are using direct drivers D2XX. The difference is at the other side, FT232 will make transfers using serial lines, and FT245 have a parralel bus to deal with.
/pisoiu
    aldevan
Re: FT245
I've used the FT245 module in a previous design. The FTDA driver is more than enough to communicate with this module. You can build a Visual Basic routine to check the buffer status and directly communicate with the USB module.
Re: FT245
Hi Bus Master,
how do I have to put a dataline in a high or low state in VB.NET for the FT245BM?
kind regards
