hm_fa_da
Full Member level 5
hi all ,
i am going to design a circuit which connects to PC through com port ,i have a question on serial interface of 8051 MCU ,when we adjust serial clock of transmiter to fore example 9600 bps , then serial data line exports data bits on each serial clock line signal ,
my question is if i adjust serial clock of MCU to 9600bps , then my receiver samples input on each signal on clock line or it samples from data line only according to theadjuasted baud rate (about each 104 uS ) ?
i mean in this way , the data of incoming to MCU should be exactly 9600 bps , or it
can be asynchronous and according to the signal on clock line and MCU samples from input on each signal of clock line ???
thanks for your help,
Regards.
Regards.
