Regards,In order to recover all Fourier components of a periodic waveform, it is necessary to sample at least twice as fast as the highest waveform frequency . So if is the sampling rate, the Nyquist frequency, also called the Nyquist limit, is the highest frequency that can be coded at a given sampling rate in order to be able to fully reconstruct the signal, i.e.,
cedance said:the Nyquist rule states that the sampling frequency should be more then twice of the highest signal frequency.
Consider sine wave with frequency let say f. Its period is T=1/f
If you sample with frequency 2f then your time step is T/2.
No assume that some sampling point is exactly at zero of our sine wave.
The next sampling point will be after time T/2 which is again zero of the sine wave, ... so following this assumption we will have zero signal after the sampling. (If we shift the sampling grid will get constant DC level instead of this zero sampled signal). This effect is the well known aliasing of the DC level over the Nyquist frequency.
IanP said:I am not in the position to aruge the Nyquist qurterion that states that .. bla bla bla 2 x Fmax.
You can buy it, or not, it is up to you .. but I am open to discuss any other options ..
Regards,
IanP
sip said:Problem in Sampling at Nyquist rate
If you sample at Nyquist rate for eg in case of sine you will be sampling only two times in a cycle. That two points will be having only zero value if you start sampling at the initial points. So finally the sampled signal will contain only zeros
