Results 1 to 2 of 2
    Points: 447, Level: 4
    Jul 2019
    49
    447
    Bulk fixing (gluing) CMOS
    Hello everyone I'm having trouble finding the material that talks about CMOS regarding bulk fixation. I know that the bulk is welded in well n (n-well) or well p (p-well) depending on its structure, because it is welded, because it is more doped so the flow of electrons is easier this way a behavior metallic. But I can't find material that specifically talks about this in a book or booklet or a reliable website in the academic area. I would like a material that talks about it.
    I do not know if it is a translation error that I am making of the following words, gluing, welding, fixing, nailing.
    Points: 41,428, Level: 49
    Mar 2008
    USA
    6,676
    41,428
    49
    Re: Bulk fixing (gluing) CMOS
    I think you're looking for things like "body tie",
    "substrate tap", "well tap" and possibly die attach
    and backside grind (if you intend to contact the
    handle that way).
