Service Notification
EDAboard.com Scheduled Maintenance for 6/4/2020
Starting at 12:00pm EST Thursday June 4th EDABoard will be in maintenance mode and be unavailable. The website is being migrated to a new web server and the software is being upgraded. With the large volume of data & images to move, migration is expected to last for 8 - 10 hours. When started the forum will go into maintenance mode and no posts, edits or registrations can be made.
Page 2 of 2 FirstFirst 1 2
Results 21 to 26 of 26
  1. #21
    Member level 3
    Points: 711, Level: 5
    Mar 2018
    63
    711
    Re: Will a filter block this waveform?
    If transmitter is 100 Mhz, not 100 Mhz - 200 Mhz, and you have 40 Mhz + its harmonics of 80, 120, 160, 200,
    then yes, a simple BPF filter works.
    Regards, Dana.
  2. #22
    Points: 31,659, Level: 43
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,650
    31,659
    43
    A better way is to use a Notch Filter at 40MHz but you cannot escape from its' harmonics.
    Using cascaded notches ( 40MHz,80MHz,120MHz etc.) will attenuate the signal as it can..
  3. #23
    Points: 18,942, Level: 33
    Nov 2012
    3,364
    18,942
    33
    Frequency of 40 megahertz, will a passband
    This is DC plus 40 MHz; DC will be fully blocked.
    Your filter has a lower cutoff of 100 MHz; it will block 50 MHz about 3 db. 40 MHz little more.
    You decide whether that is acceptable or not. It depends on the application.
  4. #24
    Points: 85,365, Level: 71
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    14,048
    85,365
    71
    I think the bottom line is this:
    If you want a clean 40MHz signal it is best to generate one as near a sine wave as possible then use minimal filtering to eliminate harmonics. If you want to start with a 'dirty' 40MHz you will need far more complex filtering and you will end up with a much more complicated circuit.
    You should also be aware that harmonics appear at multiples of the fundamental frequency. so for a 40MHz oscillator they will be at 80MHz, 120MHz, 160MHz and so on. If you are seeing other frequencies it is probably because the module starts internally at a lower frequency and multiplies it up to 40MHz with some of those lower frequencies leaking out.
    As I pointed out, those modules are designed for driving digital circuits where the only consideration is that the waveform exceeds the logic input thresholds, how clean it is doesn't really matter. They are not intended for use as transmitter signal sources.
  5. #25
    Nov 2012
    3,364
    18,942
    33
    Well, let me try to understand the other way: it can be more fun sometimes.
    Your base frequency is 40 MHz; let me assume that this is correct but the waveform is not sinusoidal. Then you will have also components of 80, 120, 160, 200 MHz etc.
    If the waveform is dirty (noisy), you will have all frequencies from DC to inf.
    If your waveform is modulated, you will have only 40+/- Alpha MHz.
    Assume further that your filter is a single stage 3db/oct slope. This (your BP filter) is same as two filters in series: one high pass and one low pass.
    Now you can see how your waveform will pass through the filter.
    Suppose you are modulating the 40MHz with 20KHz audio. The filter will scarcely touch it.
    Best is to start with clean stuff; you will have less headaches later.
  6. #26
    Points: 266,542, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,597
    266,542
    100
    Reviewing the thread from the start, I don't know if you are asking about a 40 or 100 MHz crystal oscillator? Modulation has been mentioned, but unclear which kind and how it's achieved. Is it a frequency modulated oscillator?
    Sounds like you want to use the oscillator as radio transmitter, if so, it should keep usual requirements for harmonics and spurious signals, e.g. at least 40 dB suppression of harmonics.
