Service Notification
EDAboard.com Scheduled Maintenance for 6/4/2020
Starting at 12:00pm EST Thursday June 4th EDABoard will be in maintenance mode and be unavailable. The website is being migrated to a new web server and the software is being upgraded. With the large volume of data & images to move, migration is expected to last for 8 - 10 hours. When started the forum will go into maintenance mode and no posts, edits or registrations can be made.
Results 1 to 15 of 15
    Advanced Member level 3
    Points: 4,171, Level: 15
    Feb 2016
    821
    4,171
    15
    LDO load transient response in the event of a sudden load change
    See https://github.com/promach/LDO/tree/development for the LDO circuit.
    Ignore the pictures inside README because they do not reflect the current circuit.
    Without using external capacitor, could anyone advise how to solve this issue of LDO load transient response in the event of a sudden load change ?
    Member level 3
    Points: 711, Level: 5
    Mar 2018
    63
    711
    Re: LDO load transient response in the event of a sudden load change
    Have you examined phase margin in design ?
    Also most LDOs feed parts that have themselves bypass caps, so design should
    handle C loading.
    Lastly LDOs, depending on output stage design, have issues with C loading, in fact
    spec min allowed ESR of the Cload cap. Eg. to decouple some of its phase shift
    from control loop.
    Regards, Dana.
    Feb 2016
    821
    4,171
    15
    See the following test circuit and simulation result for phase margin:
    Member level 3
    Mar 2018
    63
    711
    With the 1 uF load C, no ESR in its model, you definitely have phase margin problems.
    I am not a device designer, so will let someone else comment on best place in design
    to add compensation. You of course have to decide on allowable C loading, and the
    min ESR to "boost" the margin due to zero formed by cap.
    What does design look like w/o Cload, that will indicate if specing ESR in Cload will
    be enough to stabilize.
    Regards, Dana.
    Feb 2016
    821
    4,171
    15
    The following bode plot is without CLoad.
    Note that gain never reaches 0dB ......
    Member level 3
    Mar 2018
    63
    711
  7. #7
    Points: 10,818, Level: 24
    d123's Avatar
    Jun 2015
    1,896
    10,818
    24
    Erm... I don't know about IC design, as you know. A month or so ago I was mucking around with a discrete component (1.25V shunt ref of TLVH431, another shunt as inner supply regulator of 2V, pnp as enable, OA EA with OPA322, npn drive and pnp pass transistor rubbish but effective to overcome no model for LDO needed) linear nearly-LDO regulator of 10mA to 1.3A load in a simulator and added type 3 compensation to the EA and it seems to be very stable and have good transient response like load step, line regulation and so on, but then it is only in simulation-land so who knows... Certainly better behaviour than with no compensation. I think that's no use to you as you do not want external components, although onboard compensation R and C could be small or type 2 compensation?
    As I said, way out of my depth so sorry if reply is naïve nonsense.
  8. #8
    Feb 2016
    821
    4,171
    15
    Even with 1us rise time and 1us fall time on Iout, the voltage overshoot and undershoot for Vout is still very serious
  9. #9
    d123's Avatar
    Jun 2015
    1,896
    10,818
    24
    Is there such a thing as a 'helper'/'booster' circuit, that is only enabled on sensing a sudden di/dt change to drive pass device harder and lock Vout to the preset level, or one that momentarily shifts Vref for EA fb to compensate for sharp rise in Iout?
    Why can't you have hold-up caps with this LDO, is it internal to an IC or something?
  10. #10
    Feb 2016
    821
    4,171
    15
    @ danadakk
    I managed to get the phase margin plot back to normal by using 1.8u instead of 18u for the length of M7, M8, M11 and M17
    However, without output load capacitor CL, AC gain still could not reach 0dB.
    I am still stucked with very bad load transient response
  11. #11
    Member level 3
    Mar 2018
    63
    711
    Your phase margin at 1 Mhz is really poor. If you look at T response it takes
    ~ 2 - 3 uS to settle, which makes sense for the 1 Mhz lousy phase margin.
    You have to add a zero in response curve, starting at 100 Khz, to "lift" the
    phase margin. 60 degrees if possible at 1 Mhz.
    Not being a device designer I am not sure what stage to do that in.
    https://www.d.umn.edu/~htang/ECE5211...ter6_part1.pdf
    https://www.analog.com/en/analog-dia...e-loading.html
    http://cc.ee.nchu.edu.tw/~aiclab/tea...AIC/lect10.pdf
    Regards, Dana.
  12. #12
    Feb 2016
    821
    4,171
    15
    Why would the AC gain never reach 0dB ?
    Which circuit node introduces the zero near 1MHz ?
  13. #13
    d123's Avatar
    Jun 2015
    1,896
    10,818
    24
    Don't know, could be more than one reason, and no idea regarding W/L characteristics.
    If it operates in the same way as a discrete EA - in the feedback loop, C and R in series from fb input to Vout, or perhaps C in parallel to RfbTop is another way to add a zero, in type 3 at least.
  14. #14
    Feb 2016
    821
    4,171
    15
    See the result using the known AC testbench setup (break feedback loop using large LC)
    If I remove only C2 (removing C1 does not have observable effect) from the circuit, then see the following result :
  15. #15
    Feb 2016
    821
    4,171
    15
    I have updated the AC test setup at https://github.com/promach/LDO/blob/...ase_margin.asc
    1) The phase margin performs really bad when the output load capacitor CL is removed. Any advice ?
    2) Why would length L of M7, M8, M11, M17 affect the load transient response ? As L increases, the Vout overshoot and undershoot gets worse.
