Results 1 to 7 of 7
    Member level 5
    Points: 1,931, Level: 10
    Dec 2011
    85
    1,931
    10
    double-edged clock in VHDL
    Using Quartus 12, I would like to know why
    wait until ((clk'event and clk ='1') or (clk'event and clk ='0'));
    won't synthesize to a double edge (raise and fall) flip flop? I get this error
    Error (10628): VHDL error at test3.vhd(9): can't implement register for two clock edges combined with a binary operator
    Error (10658): VHDL Operator error at test3.vhd(9): failed to evaluate call to operator ""or""
    Also, when I wrote
    wait on clk;
    in active-hdl the functional simulation shows a double edge flip flop as below
    but quartus shows the following error
    Error (10533): VHDL Wait Statement error at test3.vhd(10): Wait Statement must contain condition clause with UNTIL keyword
    I know that is related to synthesis templates that tools use. I would like to know which one is closer to standard.
    Points: 266,464, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,576
    266,464
    100
    Re: double-edged clock in VHDL
    Because you can only synthesize circuit descriptions that are supported by the target hardware. No modern FPGA supports double clock edges.
    You can find emulation circuits for double edge clocking in literature comprised of two single edge FFs and additional combinational logic, but they have bad performance and problems in timing closure.
    Member level 5
    Dec 2011
    85
    1,931
    10
    So, do you mean the error is device specific?
    Or it is a syntax error?
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,576
    266,464
    100
    You may call it a device specific problem. But a very general problem if you don't find any logic device that has double edge sensitive FFs. As you found out, it's possible in simulator, hence no VHDL syntax or semantic problem.
    However, legal VHDL isn't necessarily synthesizable.
    Points: 38,675, Level: 48
    Jun 2010
    6,983
    38,675
    48
    Quartus is giving you its limitations. It requires that you use wait until for synthesiable templates. Its not a syntax error.
    While "wait until" can be used for synthesis, its not really very widely used. This would be the normally used (and understood) register template:
    Code VHDL - [expand]
    process(clk)
    begin
      if rising_ege(clk) then
        -- synchronous code
      end if;
    end process;
    Points: 83,988, Level: 70
    Apr 2014
    17,081
    83,988
    70
    And often double edge triggered is not useful at all.
    What´s your exact application that needs double edge triggering?
    ...and then: how is timing specified?
    One of a few double edge applications I know is the DDR interface. But for this the FPGAs often have dedicated hardware periferals.
  7. #7
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,576
    266,464
    100
    DDR logic doesn't use dual-edge triggered FFs but separate FFs triggered by rising and falling edge.
