Results 1 to 6 of 6
    Full Member level 3
    Points: 1,913, Level: 10
    Jan 2014
    168
    1,913
    10
    Class A emitter follower power amp
    What is the role of Diode and Resistor R here? Thanks.
Name:	2020-05-22 17_38_48-(The Oxford Series in Electrical and Computer Engineering) Adel S. Sedra, Ke.png
    Points: 266,464, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,574
    266,464
    100
    Re: Class A emitter follower power amp
    Obviously a current mirror biasing the emitter follower.
    Missing -VCC label at diode cathode.
    Advanced Member level 2
    Points: 3,412, Level: 13
    Aug 2016
    593
    3,412
    13
    The diode and resistor R are voltage divider components. The diode serves to turn on transistor Q2 base-emitter junction. R alongside the diode serves to divide -Vcc and to also limit current flowing through the branch.
    --Akanimo.
    Points: 10,799, Level: 24
    d123's Avatar
    Jun 2015
    1,894
    10,799
    24
    Can I ask: Isn't the diode also for Vbe temperature compensation? I'm sure I've seen AC amplifiers with diode at base like that in tutorials and some bjt app note or other, not just in emitter leg or reverse biased on base to ground.
    Aug 2016
    593
    3,412
    13
    The diode would drop about the same voltage as the transistor Vbe and so helps in eliminating the crossover distortion that would otherwise be present in the output.
    --Akanimo.
    Points: 54,530, Level: 57
    Audioguru's Avatar
    Jan 2008
    Toronto area of Canada
    8,901
    54,530
    57
    Quote Originally Posted by Akanimo View Post
    This circuit is class-A that conducts a very high current all the time. Only the top transistor is driven with the signal, then it does not produce any crossover distortion. A class-B push-pull circuit produces crossover distortion because both transistors are driven with the signal.
